SOURCE: I have the genesis media
I am sorry to hear regarding the trouble.Unfortunately, display should never go out. As you mentioned that everything else works, other than ' no lights ', this is highly suggestive of an internal failure.You can try a hard reset using the procedure below, but beyond that the unit should be exchanged or serviced.
Try
disconnecting the unit from AC power, then unplug and re plug all of
the other cables to the unit. After 60 minutes, plug the unit back into
AC while at the same time pressing and holding the power button for 5-10
seconds. This should reset the processor and hopefully allow the unit
to operate properly once again.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: l have a genesis media
Go to MissingClicker.com
There are 8 Kinds of Genesis remotes listed on the site. Choose the G-IM4 Remote and be sure select the right TYPE in the drop down menu. Price is $26.75.
about $31.00 with shipping and handling...
SOURCE: CODE FOR URC-R6 UNIVERSAL REMOTE
0385,0192,0771,0836. Check these codes. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
SOURCE: I have an Xfinity custom dvr remote and need a code for genesis media labs g -506 digital series
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts. .
