My LG refrigerator ice maker is not working correctly. The ice tray fills up and freezes but will not empty into the ice bin.
Don't buy LG refrigerator. The product is horrible. my brand new fridge is giving trouble in a span of 5 months of purchase.
It usually costs more in labor and parts to repair an ice maker.
I suggest swap it out with a new one.
SOURCE: LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
SOURCE: LG SXS Refrigerator LSC26905 ice maker
I was able to order the ice tray myself and install it in the fridge - it's not hard. I ordered from one of the parts sellers linked to at the LG website, not those listed in other posts here.
Here's how to replace the tray:
You need to remove the tray dumping mechanism to do this.
That's it. You can press that test button on the underside of the motor. This will dump the tray and immediately refill it with water so you can observe if everything is working.
SOURCE: model ed22dqxaw10 - water enters the ice maker
If the water enters as if it were on a timed basis it would be clear that your ice maker either needs rebuilt or replaced. All signals are sent to the water control valve from the ice maker. The ice maker if working properly will begin its cycle when the thermostat tells the icemaker to begin by heating the elements below the ice maker to warm slightly to loosen the ice from their ice slots. After that any confusion would be in the front of the ice maker to tell the water to come on before the ice maker emptys its ice and begins a 7 second refill of water. If you would like to rebuild your ice maker click HERE and enter your model number ED22DQXAW10 then click on photo 11 ice maker on left of screen. If you would prefer a Replacement Icemaker Click Here=> P/N: 4317943 Try disconnecting the ice maker side of your dual water dispenser to insure that it is not the problem. Dual water control valve part number Click Here=> P/N: 2188542 Like to know if the problem has been located and resolved or if you would like to continue with my assistance contact => Sea Breeze just above the Fixya Tech Support Box on right. Or try http://seabreeze.fixya.com that is having problems because of server overload. [email protected] Thanks, Sea Breeze
SOURCE: I just replaced the icemaker in my Kenmore
Congratulations, you have very good water pressure. I am not aware of any adjustment for the time the fill solenoid opens. The easiest thing I can suggest is to adjust the water flow with the supply valve. If you have the typical saddle valve, it has quite a taper to the piercing needle, and you could possibly use that to reduce the water flow, thus the volume of the fill. A little trial and error will be needed to find the right number of turns for the valve to be opened. I also recommend a water filter in the line to reduce contaminants, which makes the ice taste better. The filter should be replaced every 6-months or so depending on the amount of impurities.
SOURCE: I have a Whirlpool refrigerator with an ice maker
1. icemaker is not level. (check and re-level)
2. icemaker has a crack in the mold.(replace i/m)
3. Water level set too high.(remove front cover and adjust water level screw counterclockwise)
Testimonial: "Thanks for the fast, productive and helpful answers to my inquiry. Four thumbs up!"
