Televison & Video Logo
Mike Dabler Posted on Nov 02, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Vizio p502ui-B1E screen freezes then restarts and goes black- sound works ok channels change just image either freezes or goes black, or patterns, replaced the T-Con board problem did not go away.
Larry
Level 3:
  • Vizio Master 5,042 Answers
  • Posted on Nov 10, 2017
Larry
Vizio Master
Level 3:
Answers
5042
Questions
Helped
1241645
Points
18413
Test the various power supply voltages if your able if they all look good change the main and see if that fixes it, it should.
Testimonial: "new main board seems to have fixed the issue. Thanks!"
4 Related Answers
derbed
  • 22 Answers
  • Posted on Apr 02, 2010
SOURCE: screen goes black, while the rest of tv works
Back lights are gone or the voltage 2 them is not present. Cheaper to buy a new one.
mullen5
Jeff
  • 97 Answers
  • Posted on Feb 28, 2016
SOURCE: How to fix Multi color Vertical Lines on a Vizio E470i-AO TV
Does the menu function display the same lines? What kind of cables are using ? (HDMI, Component vid, S-video, co-ax)
Were you as tenacious checking all cables/connections as you were the electronics? Lets rule out this all too often over-looked possibility.
Do you still get the lines with nothing connected to the TV? (no source connected)
Testimonial: "The lines are present with nothing connected I am not able to see the menu screen. I turn it on and all the lines are there no image."
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Nov 21, 2016
SOURCE: I have a vizio p502ui-b1e . I noticed a slight dark spot on it the other day. Does anyone know if this is an LED that is out or is it the LED Driver? I have already tried a factory reset.
It sounds like the LED array has a defective spot.
  • 19187 Answers
  • Posted on Aug 11, 2017
SOURCE:
Those sets use LED backlights and the lights are driven to max luminosity. The individual LED failures cause the whole unit to cease
Vizio board part number match
Tengo una tv vizio d? 48pulgadas Modelo:D48f-EO no prende foquito de standby esta muerta
1helpful
1helpful
Vizio P502UI-B1E screen distortion
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
