Here's a video on changing your rear spark plugs. 2007 Kia Sportage EX rear spark plug replacement
SOURCE: How do you remove Audio-CD player from a 2002 Kia Sportage
after you remove all the screws from the dash you have to get down to a section by the pedals and remove something like the airbag to get at the last part of the dash apart. then you need to unplug the mirror and back wiper switches (opt i think). then you have access to your radio. These are all things i gathered from watching the guy at futureshop do, it was about $100 and now I don't have fm radio. but I am now going to try it on my own.
SOURCE: 2001 kia sportage blower motor resister
Rule of thumb...unless you get a better answer: look for a couple of wires on a small plate that is in the airflow of the fan on the heater/ac unit. The resistor pack is always air cooled by the fan.
SOURCE: 2000 kia sportage ex, 4 cyl.
Yes there is a sensor that controls Fuel/air ratio.It's called a MAF (mass air flow sensor)
But I think you should have the EGR (Exhaust gas recirculation)valve checked
and The TPS (throttle position sensor)maybe dirty.
Although may things can cause this issue,I would look at the items above first.
Please rate this a blue fixya
SOURCE: Changing bulbs in fog lights
Hi this is a bit of a hair raiser, first of all you need to turn the wheel all the way into the motor, left or right depending .
The plastic cover underneath is only held on by some screws and retainers take these out, the cover will be loose but won't come out, gently pry it away from the fender, reach behind and unscrew the bulb housing. Be warned there are two or three different bulbs on the market take yours out before heading off to your local spare parts dealer, it might save you the time of having to go again.
hope this helped
regards Warren
SOURCE: 2000 Sportage: where is the spark plugs located on a 2000 Kia Sp...
They are under the black plastic cover that is in the middle of your valve cover gasket. Remove the intake hose from the aluminum intake plenum on top of the valve cover and the silencer box against the firewall. Remove all the connectors from the sensors which should be 2 on the plenum and the 2 large vacuum hoses on the plenum. Then remove the 3 12mm bolts from the plenum at the throttle body and remove the plenum. You can reuse the throttle body gasket at the plenum so don't destroy it. All the other bolts are 10mm and use a screwdriver to loosen the clamps on the hose. The sensors have clips that you need to remove with a small screwdriver, then disconnect them. Remove the bolts on the cover and the cover. Then remove the bolts holding the coil packs down. Do one plug at a time. 2 of them are connected to the 2 plug wires and 2 are underneath the 2 coil packs. The connectors on the coil packs are fragile so remove them carefully. Reverse the steps to reinstall the plenum, etc.
Keep a regular schedule for inspecting the spark plugs on your 2002 Kia Sportage. According to the official 2002 Kia Sportage owner's manual, spark plugs and ignition wires should be inspected every two years or 48,000 miles, whichever comes first.
Let your 2002 Kia Sportage sit for a few hours before opening the engine compartment. You want to make sure that the engine is cool before you begin working on it.
Pop open the hood of your Sportage and locate the ignition wires, which will be attached to the top of your engine. The 2002 Kia Sportage has a four-cylinder engine, meaning there are four spark plugs each attached to an ignition wire. The ignition wires run from the engine to the fuse box, which is located in the left side of the engine compartment.
Inspect the ignition wires of your 2002 Kia Sportage. These wires will need to be replaced if they appear worn.
Disconnect the ignition wire to your spark plugs. Grab the rubber boot located near the base of the wire and pull upward instead of yanking on the wire. Remove only one wire at a time, or mark the wires with a colored Sharpie marker before disconnecting all of them. Improperly reconnecting the ignition wires can seriously affect the performance of your Kia Sportage.
Attach the spark plug socket to your socket wrench. Use the socket wrench to remove the spark plug from the top of the engine's cylinder.
Inspect the spark plug. There will be some soot, but if the spark plug is completely covered in soot, it needs to be replaced.
Position your replacement spark plug in place and secure it with the spark plug socket on your socket wrench. Be careful not to overtighten the spark plug after it has been snuggly fitted.
Position the rubber boot of the proper ignition wire in place above the spark plug and insert it with your hands. Close the hood of your 2002 Kia Sportage
Search the block for the engine block casting number. The numbers are raised, not stamped into the block and consist of seven numeric digits. The digits can be located on either side of the block. The seven-digit number may be followed with a dash and further numbers. These are change codes and are not normally necessary to identify the engine.
EX.:
Locate the casting date is located on the block. It is in standard date coding, 2.25.93, for example and may be located on either side of the block, but is commonly located on the driver's side of the block, above the freeze plugs. The example 2.25.93 decodes as February 25, 1993. The casting date may be near the casting clock, which designates the hour the block was cast. Magnum engines were manufactured from 1993 to 2002, so verifying the date code helps identify the engine.
