There 3 things that you observe:
1) The walking belt is too Tight, the deflection will be 2-3" when you lift with his finger.Adjust the https://www.youtube.com/watch?v=XyPedy7HtzM
2) the thermic swithc of the motor Tripp for the tension of walking belt.
3)the driving belt of belt motor too tight. Deflection will be 1/8" loose the bolts of motor, and adjust.
Blessing.
[email protected]
whatsApp:+50588611441
SOURCE: Nordictrack motor will not run when start button is pushed.
Likely the cover of one of the motor brushes popped off. Unplug the machine before you pop it back in place, then try it again.
If that doesn't work, most likely it's the motor control board, or possibly the console, or finally just a loose connection behind the console.
But most likely, it's the motor brush cover. I've been seeing that alot with this model.
SOURCE: My Freespirit also stops after a few minutes
Normally all these problems are in relation with motor itself, I mean, internal bearings, short circuit. So if your treadmill stops is bacause the circuit board detetecs an over current fron motor.
I hope help you
SOURCE: NordicTrack Exp 1000...stops after 40-55 minutes
My EXP000 is doing the same thing. But it is doing it when it is cold also.
http://sites.google.com/site/antiquebriggsandstratton/
SOURCE: NordicTrack Z7xi treadmill console buttons not working
Hello there. It sounds as if you may have a button stuck on your console. Thus not allowing any other buttons to be pushed. (i.e. the 4 beeps). This is usually caused by the i-fit buttons (silver buttons on the front). If the machine is only 4 months old you should still be under warranty (1 year) I believe. This problem in most instances requires the console be replaced. You can contact nordictrack through iconservice.com or by using the number on the fron of your users manual.
Good Luck! Tim
SOURCE: T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
