You might need to adjust the air pressure at the inlet of the machine. 75,000 BTUH 3.9 PSI, 125,000 BTUH 5.0 PSI, 175,000 BTUH 5.75 PSI http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjktaaNsp3XAhUKw2MKHYv5BLcQFggoMAA&url=http%3A%2F%2Fwww.desatech.com%2Fmanuals%2FConstruction%2520Heaters%2F000179-01.pdf&usg=AOvVaw3UUjdCvudIYYBI4tLQvzdM
SOURCE: my reddy heater R50,(50,000btu)when started will
the unit is working exactly as designed , the system is noticing that the unit has not fired so it shuts down so there is not a lot of unburnt fuel everywhere.
try to find out why the unit is not igniting . is the igniter sparking continually
SOURCE: TORPEDO KEROSENE HEATER DOES NOT STAY LIT. I
The fact that it lights up at all should tell you its not the ignitor. Does the unit have a thermostat? What temp do you have it set at? Does the unit blow into a corner or some way that the therostat is being activated to cut out by the hot air getting back to it before the rest of your space gets warm?There are so many questions.Does the flame go out first,or does the power to fan kik out with the flame? This could be related to a faulty or out of position tip over cut out,witch is for safety.I'm going to help you by teaching you to help yourself. Troubleshooting is a series of tests. Most every machine is nothing but a bunch of valves,and switches.First find out if its running out of fuel,,or cutting operation all together.If its running out of fuel to the firing rack you be able to see and hear it,,,NOTICE that it looks and sounds like its petering out.If its cutting fuel,fan,and power instanly then its most likely the thermostat shutting it off ,,or the tipover cutout. It could be a multitude of things.The best way to find out is to figure out how the machine works,,,understand the componits that make it up and what they do,,then single them out one at a time and test them to eliminate them from the list of possible problems. UNDERSTAND? If the ignitor clicks and the rack lights up,,,its not the ignitor,after all the ignitor IS igniting. Find out more about whats up with it and repost,,good luck bud.
SOURCE: Lawn Boy Kerosene Torpedo Heater, ph100 it sort of
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
SOURCE: I have an All Pro
First thing is to download the service manual.
http://www.desaparts.com/service_manuals.html
You need to make sure the filters are clean and that you are getting the proper air pump pressure.
If
the units starts up and runs good and slowly goes out it will normally
be due to a lack of fuel getting to the nozzle. When there is not enough
fuel being delivered to the nozzle from either a clogged fuel filter of
dirty air pump output filter the unit will slowly shut down from lack
of fuel.
If the unit shuts down while it is running properly and
the nose come is orange then you probably have a problem with a
photocell or the flame out control.
If you have other questions you can contact our service department at 269-685-4125 at extension 224
Thanks
M Cramer
www.allpartsinc.com
SOURCE: Remington torpedo kerosene heater will
Hi, Torpedo
wrote that tell you how to troubleshoot a Torpedo or Reddy
heater...
Reddy
heatman101
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
heatman101
heatman101
heatman101
heatman101
heatman101
heatman101
heatman101
heatman101
heatman101
