That is correct. Everything is accessible from the front. After removing top and bottom toe panel, front can be removed. Then remove drum. Thermal fuse is a white fuse with two blue wires going to it located in blower housing.
Not sure if this link will help but have a look.
access the thermal fuse on Kenmore electric dryer Model 66002010 Google...
Testimonial: "I am so surprised at the quick responses I received. Thank you Chris and Noel. I think that my mom and dad will have this problem fixed by a repairman. They thought it would be an easy fix but turned out it wasn't. Thank you very much for your help."
SOURCE: have a kenmore model 110.64962300
Before you begin, UNPLUG DRYER.
Remove bottom access panel by using a putty knife to depress panel clips (item 46).
Check the High limit fuse and heater for continuity. Heater (item 14) <20 ohms and HI-limit (item 47) <0.3 ohms.
If the heater or HI-Limit has failed it may be that the exhaust airflow has become blocked or restricted. Check the hose in the back ofthe machine for crushed hose. If OK, the vent pipe may need cleaning...check out www.linteater.com for vent cleaning info.
If you need further assistance please let me know..
Regards
reg501
The FixYa Team
SOURCE: Kenmore Electric Dryer 110.62922100/Runs but no heat
remove the lower front panel. the element is right there with all the access screws and wires. check the thermo relay also known to go bad..................
SOURCE: My Kenmore 90 series dryer won't heat
The thermal fuse is going to be located on the heating element housing. When you take off the front panel you will see your lint screen housing. You will need to remove that to get to the element housing. Once that's out of the way the thermal fuse should be right on top of the housing. It is small and has two small wires coming off of it. The wires should be different colors. Just don't get it mixed up with the thermostat. Just match it up with the new one that you have. It is held in place with two small screws. Let me know if you have any other questions or still can't find it, also let me know if this was helpful. Good luck and glad to help out.
SOURCE: Accessing the igniter on a Kitchenaid Dryer
Normal
0
Hi, UNPLUG the dryer. This model you need to remove the two
screws under the lint screen. Now use a flat blade screw drive and insert it in
the gap between the top and the front panel and pry the top up. Now locate and
remove the screws on the inside of the front panel in upper corners. The front
should lift off. You will see the ignitor attached to the burner. There is a harness you can unplug to test it. If the dryer is not heating at all, before you remove the front panel, you can remove the cap on the front lower panel and start the dryer. Look inside the holw and see if the ignitor glows at all.
If it glows and then shut down before the flame lights, you will need to change the coils on top the gas valve, not the ignitor.
If the ignitor does not glow at all, you will want to test the thermo fuse before the ignitor.
Normal
0
UNPLUG the dryer! Remove the rear panel of the dryer and
locate the fuse. It is white and ¼” wide and 3” long. It is located on the
blower housing. Remove the wires and check to see if it has continuity. If it
does not, you need to replace it. I know this is a lot of info but these are most common problems.
If I can assist you further, please let me know.
Vic
SOURCE: Kenmore electric dryer model 110.60942990 no
If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
If the model number you have this listed under is correct, the part numbers are as follows:
Heating Element - 279838
TCO/Hi-Limit Thermostat Kit - 279816
All these parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop around for the best price.
All your heating circuits are accessible by removing the lower toe panel dire the rear of the dryer by removing the back panel. Just remove the screws around the perimeter of the back panel and the heating circuits will be located on the right-hand side. Refer to the exploded view diagrams at the websites I mentioned for reference. The heating circuitry is located under the "Bulkhead Parts" section.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
