SOURCE: CTM Mobility Scooter HS580..need a
hi, goto www.gewizrepairs.co.uk as they supply pots for these scooters from £30.
SOURCE: Need owners manual for A ctm hs 740 mobility
go onto ctm homecare website and into rescource centre then dowloads and click on 740, regards, Bill.
SOURCE: intermitant drive power on my ctm hs 740 mobility scooter
The problem is going to be your motor. After extensive usage, the motor will give up internally and some times it will burn and melt the possitive/negative cables at its housing and it will give you issues with the batteries and the module.
Luis CTM: 909-590-1388
SOURCE: i need info or specs on a C.T.M. mobility scooter HS-686 motor model 1110-938
hi, my understanding that is a 350 to 400 watt , 24v motor, now the exact wattage should be stamped on a label mounted on motor, resistance wise you looking at about 0.4 to 1.0 ohms, that is the resistance of the brushes etc. Poorly fitted brushes or brushes that are deformed ( is the string ok ) will result in a higher resistance. are you looking for a like to like replacement.
Regards
