SOURCE: Where is battery located for Life Fitness 9500HR
These units are not self generating unit theirpower cords is in front bottom if it is missing then you will a power module got to www.sportsmith.net goto life fitness and get pricing
SOURCE: If the lcd screen for
Hi, depending on whether you have a weak battery or not, first of all replace the battery and if the display does not come up then you definitely have a bad lcd screen which needs to be replaced or check out the the wiring connections that attaches to the lcd screen to confirm if it is connected.
If the wire is connected to the lcd screen, you change the battery and the lcd screen does not come up, you have no choice that to replace the lcd screen.
SOURCE: life fitness elliptical 9500hr
When you say lights flash but wont come on, does your machine have batteries or do you plug it in?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
SOURCE: how do i get the hours info from a life fitness 9500 hr elliptical
go to the MENU, and see the details.
However your must read your instr. manual and see how to enter.
God bless you
SOURCE: I need a operators manual for a life fitness ct9500hr next generation elliptical
http://www.profitnessmd.com/Manuals/CTG%20Operations%20Manual.pdf
