Hi Leigh.
The battery supplies voltage to a precise timing circuit to generate brief pulses of low voltage electricity to a magnetic coil which swings a weighted cam (wheel) to keep everything in motion.
This cam or some other mechanical part may have become dislodged or misaligned, causing drag.
In a nutshell, a watchmaker will need to inspect it for wear.
Could be a jewel-bearing has fallen out.
Does this help?
Regards,
Clive.
Testimonial: "Yes, thank you sooooo much! You guys are all so brilliant!"
SOURCE: I have a swiss legend swiss quarts movement watch.
mcdevito75 here, Possibly the battery is weak, (Need New Battery) or the quartz mechanism is going bad, see the repair service directory here at fixya, bottom of page click on repair service directory then watches.
SOURCE: watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
SOURCE: Mens Relic watch stopped working after battry change
I suggest that your watch has an oxidized contacts and electricity can not reach the movement.
Do as folloes:
Take out the batttery,
Clean (scrape) all battery related contacts till they are shiny (use hardened steel needle for that),
Use the dust blower to get rid off any tiny dust and dirt particles after cleaning,
Refit the battery back.
Now your watch should work again.
If all written above do not help, then there is a problem with your watch and you will need the help of the watchmaker.
Do not forget to rate, please.
SOURCE: can't get my croton watch to work.
There are a few possible reasons why your watch is not working:
These are the 3 reasons why your watch could not be working. The reason will fall into one of these 3 categories, so I hope this helps!
SOURCE: swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Hi Clive, Thank you for your quick reply & excellent advice. Any idea how much this shoukd cost?
Only the repair agent can tell, depending on what needs to be done. May just need lubrication if dry.
