Garden Logo
Garry Erb Posted on Oct 28, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I fix the steering on My Husquvarna Model LTH 130 riding lawn mower?
roeb
Level 3:
  • Garden Master 819 Answers
  • Posted on Oct 28, 2017
roeb
Garden Master
Level 3:
Answers
819
Questions
0
Helped
384709
Points
2343
Go to bing.com search husqvarna Lth 130 and you should come up with a 50 page manual on the mower that might help with problem.
5 Related Answers
Anonymous
  • 42 Answers
  • Posted on Apr 06, 2009
SOURCE: need a diagram for husqvarna model lth-130 mower deck belt
Here is a diagram I have found for you.
convert?ilfn=d%3a%5cempartweb_52%5ccatalog%20data%5cemp_img%5chus%5cimages%5c07%5c36%5c0031.tif&ilsc=16&iliv=0&ilbr=0&ilif=g&ilre=8
Anonymous
  • 148 Answers
  • Posted on Oct 15, 2009
SOURCE: craftsman riding lawn mower steering shaft fell.
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Anonymous
  • Posted on Aug 23, 2010
SOURCE: Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Anonymous
  • 68 Answers
  • Posted on Jun 05, 2012
SOURCE: craftsman riding lawn mower won t cut grass
Does it die when you attempt to engage the cutting deck? If so the you might have a clogged fuel filter, bad gas, dirty air filter, bad spark plug.
Or the mower engage switch may be faulty. They are located in different places on different mowers. But should be attached somewhere along the main pivot of the engage lever. Let me know if you need more assistance. Good Luck!!
Huck Finn
  • 12 Answers
  • Posted on Jul 02, 2012
SOURCE: adjust steering on riding mower 42 inch
If this is your front end, I'd say you probably bent the linkage rods. 61 & 62.
Most alignments start with the steering wheel centered, bring the closest wheel in to alignment, then work the other one in. Again, on these the links often get bent.
Need information on fixing steering on we261 riding lawn mower.
you will have to pull the front wheel steering spindells if they dont have grease fittings and grease them
I HAVE A HUSQUVARNA LTH 130 RIDING MOWER, IT RUNS FINE BUT WHEN I PUT IT IN GEAR IT MOVES VERY SLOWLY I REV THE ENGINE MAKE LITTLE DIFFERENCE THE DRIVE BELT HAS BEEN REPLACED CAN YOU HELP
It sounds like the belt is slipping, was it the correct belt for your model? if you check the belt is it tight? if not it is possibly too long and will slip in the pulleys.
Aug 13, 2013 • Garden
Need a belt diagram for my 2000 LTH 130 Lawn tractor
Look in your manual. If need one, go Goggle husqvarna lth 130 manual.
1helpful
How do I adjust the mower lift on my Husqvarna lth 130 lawn tractor? Can't seem to be able to raise deck high enough when mowing
Some units have a dial style adjuster on the lower section of the dash. However, you may have to manually adjust the two rods under the unit that attaches the housing to the mower. Check this out first to see if this helps.
Aug 23, 2009 • Garden
Top Garden Experts
Jay Finke
Jay Finke
john h
