Pacesetter PC 7500
The owner's manual is the best resource for your question. Oil ONLY as instructed. Computerized machines do not require a lot of lube, and oiling in the wrong place could damage your machine.
Brother PC 7500 User Manual
Go to this link it might help you out. How to oil pc 7500 sewing embroidery machine Google Search ..
and this link you might find your manual. Pacesetter PC 7500 sewing embroidery machine manual Google Search
SOURCE: how do i oil this machine , please
You should not use WD40 on your machine. Use machine oil, you can p/u singer sewing machine oil really inexpensively. Also if you write Brother via the website they will email you a diagram of where to oil, I've found them very helpufl.
SOURCE: oiling Brother Ultima 2001 sewing/embroidery machine
The only place you can opil an ultim is inside the bobbin case and around the bushings in the front end. Do a search for Anns fix it and you will find more than you will ever need for these machines
SOURCE: Feeder doesn't work on Brother PC 8200/8500 sewing machine
Look for a mechanical switch that engages the lower drive mechanism.
Testimonial: "That was the trick. I knew it had to be something simple but I couldn't figure it out."
SOURCE: Oiling a pacesetter
No oiling by the user.
Computerized machines are lubricated and sealed in the factory.
If you are the original owner, you could invalidate your warranty if you go beyond the maintenance routine described in the manual.
To keep the warranty, your machine is to be serviced by an authorized Brother tech on a regular basis - once a year if it gets heavy use.
General maintenance, per the manual, will keep the machine in good working condition.
SOURCE: feed dogs stuck in down position
The feed dogs come up as soon as you start sewing again. Just make sure they're in the up position and start sewing.
C. POSITION OF TOUCH PANEL
STANDARD
The deviation of the liquid crystal display and touch panel should be within 1 mm when the touch
panel is pressed.
ADJUSTMENT
1. Turn on the power switch while holding down the start/stop button, backtack button, and
NP button simultaneously.
2. While holding down the start button, press the + positions 1, 2, 3, 4 and 5 on the screen in
order. If the buzzer sounds once when 5 is pressed, the position is okay. If the buzzer
sounds several times, the position is erroneous; therefore, adjust again. (When pressing
the screen, use a pencil (or match) with a round tip.)
3. Turn on the power again, and confirm that the screen display and touch panel positions
match.
ADJUSTMENT
match.
