Can't get the child lock off
You can use theV-Chip Parent Lock to
Block or Allow programs based on the
ratings sent by the broadcast stations.
The default setting is to allow all programs.
You can block programs by the
type of program and by the categories
you want blocked. Or you can block all
programs during a specific time period.
To use the V-Chip Parent lock, you will:
• Enter a passcode
• Select theV-chip ratings and categories to block
• Select theV-chip hours to lock and unlock for television programs
• Select lock by time
Enter a Passcode
MENU
I. Press _ to display the Main Menu.
2. PressAorV to select V-Chip Parent Lock.
PressE_ R,
3. Using the number keys, enter four numbers. To
delete a character and move back one space, press
CANCEL ENTER
. Press _ to set the passcode and go to
theV-chip ratings menu.
MENU
4. To exit without entering a passcode, press _ to
HOME
go to the previous menu or _ to return to
television viewing.
IMPORTANT
If you forget your four-digit passcode, please
see Appendix 3 : Procedure for Bypassing the
After you set the lock, you will need the secret code in order to:
• view a locked program,
• view the locked TV, or
• cancel the lock.
If you forget the code, you can view the locked TV without entering the code. To do this, simply
press the buttons on your remote labeled "QV" and "9" at the same time whenever your secret
code is requested. Unlocking theTV this way is temporary.
To change or permanently cancel the lock:
I. Turn on your TV. If the TV requests your secret code, press
and_ at the same time.
MENU
2. Press _ to view the main menu.
3. Use the • o rV to select ..V..-Ch p Parent Lock and press ENTER .
4. The on-screen display will ask for your current passcode. Press
and _ at the same time.
5. The on-screen display will now ask you to enter a new code:
MENU HOME
• To cancel the passcode permanently, press _ or _ .
• To change to a new passcode, use the number buttons to enter a
new code, then press E_R,
IMPORTANT
You must use the remote control included with this
TV. You cannot use a remote control from another
Mitsubishi component and you cannot use "Univer_
sar' remotes from other manufacturers.
65
