There are a couple or reasons that this might be happening. One is the heating element in the bottom ALSO heats the water to a higher temp. If it is burned out, that can cause the issue. Another is the fill valves may have screens on them that are full of debris.
The last would be the control panel and it is not cheap.
SOURCE: Dishlex dishwasher global 300. Dishwasher
Some diswashers have a sump in the bottom with a float switch. If the water level overflows the float will activate the switch which will kill the machine and run the drain pump continuously.
SOURCE: Remote is displaying C7 76
Contact Paloma/Rheem customer (800-432-8373) support and notify them you are getting a code "76" error. Rheem has recently extended the warranty on the "Burner Control Assm."; which is your problem. The C4-C8 portion of the error code, is where the unit stops the ignition process...burner fails to light, or gives you intermittent hot water. In either case, contact customer support. However, I do have a detailed process on how to repair the printed circuit board yourself. Any further questions, you're welcome to email me at [email protected] .
Good Luck, if this has helped you in any way...please indicate so.
SOURCE: My Samsung DMR57 Dishwasher gives me error code
Our unit started displaying code 9E after filling, draining and filling again. At the beginning it was enough just to restart it. Finally this trick didn't work anymore. Before calling service for out of warranty I decided to take the unit out of the cabinet and start it. Of course this didn't fixed the problem. Then i noticed where the water comes in and I took off the panel on the left side bottom.
Under the panel there is a white box that has a floater inside. The floater is pushing a lever that actuates a micro switch. I noticed that the lever wasn't moving as the machine started to fill in with water. The lever was stuck. An easy touch on the lever fixed the problem and the machine started working.
I will put back the washer for now but if it happens again in the next future i'll have to find a more permanent fix.
SOURCE: I have a Black & Decker digital steamer Model
I have the exact same problem - still no solution - this is the only posting I could find ... anywhere! If I figure out something, I will let you know. I love the steamer, but the beeping is also driving me nuts!
SOURCE: Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
