SOURCE: monitor gone dead
does your tower turn on? just check if the monitor is the cause of the problem..
SOURCE: Monitor wont power up after comp initial boot?
hi.....
you will face this kind of display problem if the video adapter IC(integrated circuit ) is dead or if it is getting over heated in the short time in the motherboard ...
you just have to do is you must replace that video adapter IC ...
just contact the motherboard technician and get that IC replaced ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
SOURCE: Relisys TL766 monitor. OSD menu continually open, wont close. Standby button doesnt always function.
Here is a definite solution to all those having problems with OCS menu on Relisys TL 766 Monitor.
Having tried many of the posted solutions none of which worked. The only option was to visit my local PC repair shop who disconnected the OCD monitor for UK £15.00. Spare parts for this model are no longer available. Only down side was the power indicator light in middle of now redundant control buttons does not work. Otherwise a monitor works perfectly. NO MORE STRESS.
SOURCE: Sytem wont boot
This time your system is very ok... theres a possible reason why its automatically on without pressing the button and cannot see a device even hard disk...
Here is a tip:
1. Check the CMOS Battery maybe its weak, or try to change it a new one, and
2. Change also your power supply it might the current flow of electricity are not normal... i know its ridiculous but i experience just like yours...
SOURCE: hi, my old compaq presario 1500 wont boot up and
remove battery ,remove power,plug hold power button for about ten seconds , plug power in press start seeif tht fixxes it
