Measuring Tools & Sensors Logo
Brian McCormack Posted on Oct 26, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where do I get the running software for Digitech XCO348 weather station. I don't know where to download it from
Steve Pack
Level 3:
  • Master 7,125 Answers
  • Posted on Oct 26, 2017
Steve Pack
Master
Level 3:
Answers
7125
Questions
Helped
2273435
Points
27938
1 Related Answer
Anonymous
  • Posted on Dec 16, 2012
SOURCE: Software for Weather Station EC-WS115
reguire driver/software for ec-ws115 wireless weather
My figure has DigiTech XC-0366 wireless weather station is not collecting the outdoor temperature
Your 'figure'??
Normally it has to be done in order. Remove both lots of batteries. Put the base unit batteries in first and then put in the outside unit batteries. they should pair. In fact the manual states that.
Instructions:
- Open the battery compartment on the weather station and insert 2 x AA
batteries, taking care to put them in the correct polarity. Close the battery
compartment.
- Open the battery compartment on the transmitter and insert 2 x AA batteries,
compartment.
Note: Ensure to install the batteries into the weather station and transmitter
within the same hour to ensure that they synchronize properly.
DigiTech XC-0366 User Manual - ManualsLib
https://www.manualslib.com > ... > Weather Station
View and Download DigiTech XC-0366 user manual online. Wireless Weather Station With Outdoor Sensor. XC-0366 weather station pdf manual download.
How do I calibrate a Digitech rain gauge. It is reading too high.
Question edited for clarity, two questions made into one.
Question moved from Digitech Music to Weather Station
Duplicate post deleted in Cars and Trucks. Refresh page to see your question published.
Help in the link. All of the weather stations are made by the same company.
https://www.google.com/search?q=calibrate+a+Digitech+rain+gauge
Change Location Digitech XC0366 weather station
Page 6 of the manual refers
DIGITECH XC-0366 USER MANUAL Pdf Download ...
Temperature Alert Setting: You can program your weather station to sound an alert whenever the outdoor temperature exceeds the upper or lower pre-set limit.
3helpful
How do I change the temperature display on a Digitech XC-0366 weather station from Degrees F to Degrees C?
Pressing the - (minus) button on the back toggles temperature units. Pressing + (plus) toggles barometric pressure units.
Download Digitech Weather station XC0346 Manual
To set station Hold SET key down for 3 secs. Press SET key to select setting in this sequence. 1. Time Zone 2. 12/24hr format 3.Manual time setting HR/Min. 4. Calendar setting y/mm/dd 5.Temp display C or F 6.Air pressure display hPa or inHg 7.Relative pressure setting from 919.0hPa-1080.0hPa 8 Pressure threshold (sensitivity)Default 2 9.Storm threshold Default 4 10.Wind speed reading km/h, mph etc 11 Rainfall display in mm or inch. Use the + and History keys to adjust values (History key is - ) When replacing batteries Fit outside unit ones first then fit inside unit ones in that sequence so it can interpret the security code.
9helpful
2answers
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
