BIZHUB 420
SOURCE: what is the problem code c-2801 in my konica
Have you check the Printer control board. Also does the toner bottle turn? You can force it in 47 Mode. to turn the bottle motor CW or CCW
SOURCE: minolta bizhub 420 code c2403
this error code means there is a problem with the toner bottle drive most likely the toner rotation sensor will need to be replaced
SOURCE: How to fix Error Code C3901 on a Minolta Bizhub
Enter service mode & Clear All
Utility>Stop>0>0>Stop>0>1
All of this within 3 secs.
Please Rate me.
SOURCE: bizhub 420 error code c-2801
konica minolta bizhub 420
error code 2801 plesce relese the code prectical met
SOURCE: how to reset fuser unit forkonica minolta bizhub
In tech mode :
System 1
Initialization
Counter Data fixing Unit
Start button
Shut off the copier ans switch on
