Sometimes manufacturers will combine more than one model in a manual. The similarities are close enough that it should be usable for your model. Just because your model is called a "quilt" model, there is really not a lot of difference between the way the machines operate. Usually, one will have more or different accessories, stitches, or options than another, but they all thread and stitch the same.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&ved=0ahUKEwiCl7ar547XAhVlsVQKHT0NCPAQFggmMAA&url=http%3A%2F%2Fwww.pfaff.com%2FSiteMedia%2FPFAFF%2FProducts%2FMachines%2Fexpression-line%2FManual%2Fexpression-3-2-4-2-manual-EN.pdf&usg=AOvVaw00vbTPKaCOh98HQ2-QnKQP
Below is the result of my search for Pfaff 20B manual
Pfaff 20B manual Google Search
https://www.google.com/search?q=Pfaff+Quilt+Style+20B+manual&ie=utf-8&oe=utf-8
Go to this link and you will need to look and see if your manual is there. user manual Pfaff Quilt Style 20B Google Search
SOURCE: I have the Pfaff Quilt
No the stitch is only on certain machines like the lady sitchb studio locate din Albany NY.
Thank you,
Marie
SOURCE: Pfaff quilt expressions 4.0 shows
A lot of these Ex 4.0 have defective cutter motors. The arm that the cutter is attached to passes by a sensor that tells the machine when the cutter is at the rest position. And what is happening is that the arm is no longer in place to tell the sensor where it is, and it stops short of the rest position. This part is covered by PFAFF for a 5 year period. You'll just have to have a PFAFF dealer install it and pay a labor charge.
