Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://homenol.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
SOURCE: height,width,&length of 42 in tv
The TV itself measures 31.5 x 23.7 x 9.9 inches (WxHxD) with included stand. You want to make sure you have at least 4 inches of clearance for airflow on top of those dimensions.
SOURCE: sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press tv guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
SOURCE: need sabre tv code for universal remote?
The code for Sony televisions work.
0128 works for the GE Universal remote.
SOURCE: Code to progarmme Tevion TV
Might be a bit late - but I hope this helps..
Tevion is made by Medion..
The only code I find for them is 191
Good luck..
