I hit Voicemail and their is a old old recording I left. How do I delete that.Don t want voicemail I just want people calling to leave message on the factory set recording answer machine
SOURCE: voicemail answering
that depends on your celphone options, you have to correctly configure the voicemail option before any caller can leave a voicemail.
seting up the voicemail aint that hard. By pressing the number 1 then talk or holding down the 1 this will prompt you to set up your voicemail. An automated system should walk you through the setup of the voicemail. Listen careful and you'll be set up in no time.
hope this helps
SOURCE: switching of voicemail option
In most cases you need to call your service provider and have them remove the voicemail feature from your account. You can have it re added when you return, though you will need to set it up again.
SOURCE: vtech model 6053 answering machine will not record message
Perhaps your answering machine needs to be set set to accept messages. Maybe your message machine memory is full of messages?
