MY OVEN DOOR SWINGS UPWARDS, and I need to remove it to get better access to clean the oven
Slightly open door, approx 6 inches, and pull up. this normally allows the door to be removed
See if the info at the link helps. Home Appliances How to Remove the Oven Door
SOURCE: Neff Oven handle loose
The door can be seperated by screw on the side of the door, Put lock washers to insure futer tightness.
SOURCE: cleaning glass in oven door
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. The glass slides out from the tabs and you can give it a good cleaning at this point. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Testimonial: "Thanks for the advice and it worked like a charm, like you said make sure that you take your time and it works TX "
SOURCE: Removal and disassembly of oven door
The panels on the door , specially the glass panels can be removed easily if care is taken to remove the fitting screws.
You can use a good cleaner glass cleaner to remove any dirt that has deposited on the frame and glass panels.
Once the glass is dry it can be refitted , care taken to use gloves so as to avoid hand impressions .
Below are instructions on how to take your oven door apart to
remove any stains that may be caught down in the door vents. Tools needed: good Phillips head screwdriver or small quad bit
driver. B. With door in broil stop position lift door assembly off
hinges. C. Lay door on table, position so that handle hangs freely over
edge of table D. Remove 2 screws and washers that secure handle to lining
assembly. E. Remove 8 screws that attach textured steel door wrapper trim
to lining assembly 3 at top, 3 at bottom, 1 on each side F. Lift door lining up and out of wrapper trim assembly. G. Lay lining assembly on table with wool shield/inner part of
lining facing up. H. Remove 2 glass clamps via 2 screws per clamp. These clamps
attach innermost clear glass to wool shield. I. Lift out center clear glass from wool shield, this glass
just lays onto the wool shield and is held in place by the glass/ clamps in
item
H.
K. One glass that remains in door lining assembly can at this
time be cleaned without further disassembly the lining assembly. L. Reassemble in reverse order.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
Look for a manual lever to unlock the oven. If there is one, it will probably swing back and forth horizontally, just below the upper edge of the oven door.
Swing the locking lever, if one is present, all the way to the left. This should unlock the oven. If there is no manual lever to unlock the oven, it may be unlocked using push-button controls.
Check to see if the oven is in a self-cleaning cycle, or has just completed a self-cleaning cycle. If so, the door will unlock automatically once the oven has finished the cleaning cycle and cooled completely, which may take several hours. You cannot unlock the oven before it has cooled.
Unlock the "Clean/Off" button. Depending on the brand and model of your oven, the button may display both of these designations or just one. If your oven door is locked, but the oven is not warm and is not in a cleaning cycle, unlock it by pressing and holding the "Clean/Off" button.
