Question about Leisure Kitchen Ranges
Do you know how to remove the hob off a Leisure cookmaster 101 ?
5 Suggested Answers
SOURCE:
  • 72 Answers
SOURCE: Hi, I have got a Leisure Cookmaster 60 Double Oven
Check that the oven is sitting level on the floor. If so then the spring may have broken in the lid hinge.
Posted on Jan 04, 2010
SOURCE: location of thermal fuse in leisure cookmaster
where is the thermal fuse located in a leisure cooker
Posted on Nov 30, 2010
kevin_getz
  • 1032 Answers
SOURCE: My cookmaster 101 fan oven is not getting up to
It probably has a bad thermostat. Those things are made to be disposed if something breaks.
Posted on May 07, 2012
rgall3285
  • 63054 Answers
SOURCE: My leisure cookmaster 101 as got two ovens and one is not working also the clock as stopped as well do they have a battery anywhere thanks kath
no battery .
Posted on Apr 01, 2016
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
The glass lid on my leisure cookmaster 101 FRKP won't stay up. How can I fix it?
sadly I can find nothing about a glass lidded cooker of that MAKE model
Oct 28, 2017 | Leisure Kitchen Ranges
How do I change the glass lid on my cooker
Buy one direct. I am guessing it has a straight forward screw off hinge. Nice range!
Spares for Leisure Range Cookers Official UK website
Jan 29, 2016 | Leisure Cookmaster CM101NR
I have a LEISURE COOKMASTER 101, it has a clock with buttons below that include a BELL, COOKING POT , STOP , PLUS and MINUS button below it. It has on the left a grill/oven at the top and an oven below...
Hello would you happen to have a model number or any serial number on your LEISURE COOKMASTER 101 I will be trying to obtain your specific manual and not provide one that is generalized and these numbers help to locate your exact unit. Thank you I await your reply
Rick
Oct 28, 2011 | Refrigerators
Location of thermal fuse in leisure cookmaster range cooker
Jul 22, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Kitchen Ranges Logo
61 people viewed this question
Top Leisure Kitchen Ranges Experts
Andrew Taylor
Andrew Taylor
Chuck Graybill
ray gallant
ray gallant
Are you a Leisure Kitchen Range Expert? Answer questions, earn points and help others
