Apple iPod touch Second Gen (8 GB, MB528LL/A) Digital Media Player Logo
Anonymous Posted on Jul 29, 2009
Ipod touch disabled
I forgot my passcode and ipod touch has been disabled,please help me enable it.
serial number: ee1ea0045700ac22e5a1a4edcbe4704292ecd
firmware version: 1.1.0
manufacturer: apple inc.
mode name: apple ipod
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Jul 29, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
0
Helped
8407
Points
72
If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode.
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present.
Anonymous
Level 2:
Novelist:
  • Expert 117 Answers
Anonymous
Expert
Level 2:
Novelist:
Answers
117
Questions
Helped
49858
Points
281
This worked!
http://www.youtube.com/watch?v=zKQV3qlpiEs
Good Luck!
Ruben
Forgot id and password
If you forgot the passcode for your iPhone, iPad, or iPod touch, or your device is disabled Follow these steps if you've forgotten your passcode, or if a message says that your device is disabled.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
1helpful
2answers
Please help reset passcode - forgot the code iPod touch
You can connect your iPOd on the computer which you primarily use with your iPOD, then open Itunes when you disconnect from it it will be no longer locked.
Hi sir . i have a i pode touch and its
Call i pod support. they might beable to help. have the serial number ready.
Forgot passcode to ipod
You'll need to restore the software with iTunes. Select the iPod in iTunes, under the Summary Tab, select Restore. You will then need to resync it as well.
2helpful
MY IPOD TOUCH IS DISABLE I DONT KNOW HOW TO ENABLE
here's how to enable it.
1. Turn on your iPod (in my case it would only get as far as displaying the Apple logo
2. Hold the power and home buttons down (the iPod will power off after 10 seconds, but keep holding those buttons down)
3. After the iPod powers off, release the power button (but keep holding the home button down)
4. After a couple more seconds, you should hear that magical “ding dong” that means the iPod is coming back alive, and that Windows has detected it. You may even see a little “New hardware” popup in Windows. It is now safe to release the home button, and your iPod is in DFU mode.
5. Now iTunes will see it as a DFU’ed iPod and should ask you to automatically restore its firmware.
6. iTunes has to download the new firmware, and it takes a while, so go make a sandwich.
41helpful
5answers
Ipod touch disabled
Try turning off your ipod, holding the home button, and plugging it in, while still holding the home button, until a picture of the ipod cable appears pointing to the itunes symbol. this will reset you ipod, and you don't need the passcode to make it usable again.
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
