Stove top works. Oven shows that it turns on but then it immediately gives the beep that means that it is heated to the proper temp (it's not). Sometimes it gets an error that means that the oven is not getting full voltage. I checked the outlet and found loose connection where one of the blades for the cord goes in I replaced the outlet. I have had a board go bad on it before while under warranty and am thinking that it is the same issue.
SOURCE: oven will not start, stove top works fine, possible lightning strike.
hi thom,
You are likely correct, you may need a new control panel, they are very sensitive to power surges. If you are handy you may be able to find one cheap online and replace it yourself, just be sure to unplug the stove or turn off the breaker before you work on it. if you have any questions on how to do that please contact me.
SOURCE: No power to upper oven 'bake' heating element.
Sounds like you have it figured, need to spend some moola..........
You can ohm out the sensor to the oven should be about 1100 ohms at room temperature.((the sensor is the little rod with two wires attached to it sticking in the oven, as temps change resistance changes which is read by the board) The upper and lower oven sensors are probably the same,you could just swap them to test, but probably not necessary,might also be confusing if you do not do a lot of testing on a regular basis. Remember to unplug unit for safety.
The bake element if it was not bad should be about 20 ohms, bad would read open........
SOURCE: Oven appears to start, takes forever to preheat,
This is what I would do: I would unplug the range and connect my test cord to your range cord. I use an ammeter along with my test cord to read the amp draw of the bake ignitor. If it cannot get above 3.5 amps I know the ignitor is bad or weak. Since the oven is working that means there is a good circuit. In order for the safety bi-metal to open the amp draw must reach 3.5 amps or better. So to me I am thinking bad ignitor. To get to it I remove the door oven racks and bottom, I then remove the flame spreader and unplug the quick connect to the ignitor. I remove the burner and ignitor and replace the ignitor on a work bench. I am too old to be bending over and trying to do any parts replacement inside an oven. LOL. I have a training film which shows how the silicone carbide ignitor works HERE. Post a model number and I may have a service manual, do not forget to rate the answer.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "This advise seems right on. Thanks for your fast and detailed advise. Steve"
If
your electric oven is taking too long to heat or just not heating up
right, then check out this tip that will give more detail about your
problem.
Oven
Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
If
problem.
Oven
heatman101
