SOURCE: Date/time change
Press program
then 0
(this will then display current date and time - overtype as follows)
eg. for Friday 2nd November 2007 8:58 am you type the following
071102 (date backwards) [space] 5 (Friday is 5th day of week) [space] 0858 (time) [space] 0 (0 is am, 1 is pm)
Press the store button and then program button to exit the programming.
SOURCE: Time Change
It can be changed from any phone that lets you into programming. We usually give everybody access to make changes like this, but by default, the phone designated as the Manager or Operator is usually given that access. Try ext 101.
When you get there, press PROGRAM **1234. If your display reads SYS-PGM No?, then it will work. Dial 000 and STORE. You will see the Date. Press SP PHONE! Now you will see the time. Dial the new time and press STORE. Press HOLD and PROGRAM to exit or just pick up the handset and drop it back down.
If for some odd reason you can't get into programming from ext 101, then you might have to search for the manager's phone, or call your installer to make one or all of the phones have access to programming.
They can allow you access to other programs, or even give you the installer password to get into all the programming.
Carl
Testimonial: "Thanks, great help"
SOURCE: How do I change my message on the phone. KX-T7665
dial 100 and select 5 for mailbox management
SOURCE: How do you change the display to show the date and
Since you can't exactly press the INFO softkey :-)
Try the TRANSFER button on an idle phone. It has 3 steps, one of them will be the date and time.
Carl
SOURCE: I have a panasonic KX-T7665 how do I forward calls
The simple answer is on the intercom dial *7102 9 number #. That forwards all calls outside. However, outside line and trunk-to-trunk programming has to be programmed into the system.
There are other conditions located in the Operating Manual under Call Forward. In mine, it's on page 71.
Carl
