SOURCE: My Saeco Giro keeps flashing red, what's wrong?
Hold the water button in for about 15 seconds.
SOURCE: My Saeco Talea Giro have the wave like symbol with
It is saying..it's time to descale the machine. If you want to get rid of it, just press the water button and hold it for 5 secs.
SOURCE: Flashing Red bulb
That is the descale light, you should run a descale through the machine. After you have done that hold on the water button and the descale light will go away
SOURCE: Hi, I have a Saeco Talea Giro Plus machine and
Hi Natasja, try pull out the driptray and dreg draw while the machine is on and wait about 10 secs. When the red light start flashing, put the parts back. The red light should dissappear. Good luck.
SOURCE: Saeco Talea Giro Plus, descaling
Try doing another rinse cycle until water tank empties. I had to do that a couple of times, then the red exclamation mark came on. Then I turned knob to off position, refilled water tank, pressed the descale button for 6 seconds, green light came back on and it did its priming.
