Epson is one of the renowned brands in the market and is often preferred by many people in terms of affordability and quality product. Its excellent functioning has made it the most reliable to use at workplaces, but both efficiencies and flaws co-exist in each device no matter what the product's brand is. So, despite its excellent functionalities sometimes people have to face the issues and some of the most common is Epson XP 430 Paper Jam. To fix this issue visit: https://www.newliteitservices.com/support-for-printers
Not sure if you have the manual put this link will give you the manual if you need it... Epson XP 430 User Manual Paper Jam Problems ...or try this link might help you out.. Epson xp430 paper jam Google Search
SOURCE: Epson AcuLaser CX11N ADF Paper Jam
I had a very similar problem with the ADF, it resulted in ADF paper jam - message and then in Req Code 2011.
I checked sensors and everything else, then called a epson service professional.
After telling him the Req Code, he knew the problem and said that the problem is the board, which needs to be exchanged, mentioning that this spare part is expensive.
I then checked the whole ADF again, now opening the long grey cover on the backside, I disonnected the connector cable from both sides and - using a multimeter - checked this connector cable for breaks.
Result: the violet cable was broken, so I soldered in a new wire, using the last cm of (old) wire on each side - and now the ADF works fine.
This cable is easy to change if you get the spare part, there is a connector plug on each side, on the ADF side is an additional ground wire (green) fixed with a single screw. Thats it !
For the electronic experts: the configuration of the connector:
sourrounding metal cover = ground, thick green Wire on the ADF side
If you turn the plug that way, that the two single contacts are on top, these are the colours:
1st row: brown - black
2nd row: green - yellow - orange - red
3rd row: grey - violet - blue
Hope this helps
SOURCE: epson jammed paper
Check for the compatibility of the paper you're using by visiting www.epson.com and selecting your region. Also, I might add that make sure paper is properly loaded.
SOURCE: EPSON R 300 SAYIN PAPER JAM WHEN NO PAPER JAMMED
Make sure that the paper path is completely clear and clean the paper sensors with a q tip. They get very dusty!
SOURCE: Epson NX415 Paper jam. I took paper out but it's
Check for other bits of ripped off paper stuck in your machine.
Try turning off your printer for 30 secs and turn it back on.
