Here are the steps for adding a new contact:
More items...
How do I add a new name to an existing list? - Constant Contact ...
https://community.constantcontact.com/t5/Managing-Contacts/...new...list/td.../109579
How to enter new contact on contacts list Google Search
SOURCE: transfer contacts list
1. From the standby screen (the first screen when you open your phone), go to the menu.
2. Scroll to the address book and press select.
3. Scroll to the address you wish to copy (or any address if you want to copy all of them) and press the menu key.
4. Go down to copy and press select.
5. Select "Entries" to copy just that one entry or "All to SIM" if you
want to copy all your addresses to your SIM card, or "All to Phone" if
you want to copy them all to your phone.
6. Select Merge or
Override. Merge will combine any addresses that are already on your
card with the ones you are now copying, Override will replace anything
that is already there with the ones you are now copying. Be careful in
deciding which you want to do since Override will delete anything
previously saved and merge will duplicate any that were already saved
and are being saved again.
SOURCE: contact lists in samsung tocca
the only way i have found is to fully reset the phone ( back to how a new phone comes) , copy all contacts onto your sim, and any other stuff on your phone you dont want to lose. like photos prob best to plug it into PC and make a copy that way.
just in case i removed the sim from the phone and restarted it in no sim mode.
then dial
*2767*3855#
replace sim, and there gone
this is a bit of a pain doing it like this but it gets you out of any difficuilt situations if your texting people you should not be !
SOURCE: windows live messenger contacts list not showing up
I emailed microsoft about this problem,heard back 2 days later and there expert advice is.......It Is a known problem that Is currently being Investigated please except our regrets that this has happened and please roll back to messenger 8.5 untill the problem Is resolve.I had already done this when I got the email,but here is there workaround/solution
As
a workaround, you may try downgrading Windows Live Messenger. Please
follow the steps below how to uninstall version 2009 and install
version 2008.
a. Click Start, click Run and type appwiz.cpl and then press ENTER.
b. In the list of currently installed programs, locate and select Windows Live Essentials and then click Change/Remove.
c. Click Uninstall.
d. Follow the prompt on how to remove all Windows Live products accordingly.
e. Download version 2008: http://www.microsoft.com/downloads/details.aspx?FamilyID=7a1aae73-48cc-4f7a-b445-0487bd5e84ef&displaylang=en
SOURCE: the contact list in my new msn live 9 is missing
go to the file in the top of the msn then searh for tools and to the botom and see there is a options then click it and u will see privacy then there are 2 side 1 is allow and 1 is bolck search the 9 missing contat in the block list and u will find it :)
SOURCE: Contacts missing from my contacts list
Hello from Portugal,i used to have the same problem,when i logged to msn no contacts although in hotmail they where all there,so i uninstalled windows live essencials(all programs) then downloaded windows live messenger 2009(again) but this time i only installed the messenger app!problem solved now when i log in all my contacts are there and the messenger works at is full power(lol) hope i helped someone and sorry for my english!
