SOURCE: Leather wrist strap
I would scrap the strap - the odours are caused by the tanning chemicals getting wet. Retain the fastening and purchase half a meter of nylon ribbon loop it through the case pegs on one side glue them together and pierce for buckle holes. On the buckle side loop it through both case peg and buckle and fold and glue. You have a choice of colour and it cost only fraction of a new leather one- also you will have enough left to make two straps
SOURCE: how to change the strap of leather to the gel strap technomarine
What is the reference of the watch?
On the Cruise collection, the process is very simple:
1.
(To
remove band) Squeeze the easy release spring bar to one side until it detaches
from the watch case completely, do the same for both bands.
2.
(To
attach new band) Take the straps that you want to put on and squeeze the easy
release spring bar with your (nail or screwdriver) and insert into little
groove, it should snap right into place
3.
Do
the same for other band
If you need more information, please contact us [email protected]
SOURCE: Mens Versace leather strap. How do I adjust the
Well i am going to roll the dice and assume you have one of the ez clasps but if I am wrong you can send the model number and we will figure it out.
To adjust the ez clasp pull up on the front of the clasp loop while pushing down on the band. Rather than the traditional buckle and prong set up, the prong here is underneath the clasp loop.
Hope this helps. Thanks!
SOURCE: broken watch strap
Is it totally broken? Send me a picture of the damaged strap if you get a minute..I might have some ideas. JR8712 - is that a brown cuff one with the gothic seconds?? [email protected]
