SOURCE: need instructions to reset sub dials on Nautica Chronograph watch
Pull out crown to the first click and push and hold pushbutton at 2 or at 4.
SOURCE: Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
SOURCE: Battery was replaced by a jeweler. Since that
As the jeweller is not a watchmaker, he/she even did not realise the watch is not working properly. It sounds like your watch is having jammed gear train or the jeweller did not know how to reset the watch. Go to this website: www.tissot.ch
If you will not find solution there, you will have to look for watchmakers help.
Rate me, please.
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
SOURCE: hi my Guess chronograpah 123503G1 keeps getting
mcdevito75 here, Sounds like your Guess watch neds some service, cleaning, oil etc. You can check with the repairservice directory right here at fixya, bottom of this page click on repair service directory then watches.
