Cooktops Logo
Val Bird Posted on Oct 22, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you clean a Brilcon ceramic electric cooktop
Paul Carew
Level 3:
  • Master 3,807 Answers
  • Posted on Oct 24, 2017
Paul Carew
Master
Level 3:
Answers
3807
Questions
Helped
1298613
Points
10523
You can buy ceramic cooktop cleaner
5 Related Answers
Anonymous
  • 111 Answers
  • Posted on Dec 19, 2008
SOURCE: whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Anonymous
  • 76 Answers
  • Posted on Jan 08, 2009
SOURCE: burner on electric ceramic/glass cooktop is getting too hot
sounds like you need a new thermostat
Anonymous
  • 18 Answers
  • Posted on Jan 31, 2009
SOURCE: I have a new Jenn-air ceramic cooktop- what do I do to clean it.
Greases lightning is a great cleaner for cooktops and work great on the grease filter it is sold at most stores. Be careful however when cleaning around the control knobs. They do have a rubber dust cover over each switch but if any fluid drips past it and into the switch it could short out the control.
Anonymous
  • 1891 Answers
  • Posted on Dec 03, 2009
SOURCE: How much will it cost to replace a broken Electric
the elect cok top mod fec30s7e ( main top in blk/ steel / or glass = 199.49 + shipping ) the mod fefb79gsa is a white top 208.22 + shipping / labor is on both about 100.00 = tax .. mm
Anonymous
  • 949 Answers
  • Posted on May 05, 2010
SOURCE: My ceramic cooktop has cracked. Can I just order
You can get the main glass top, the part number is WB62T10525 and it runs just under $300.00, it is shown here as 51. It does take a bit of dis assembly to install it.
I can't unlock the stove on my kenmore ceramic cooktop
I was cleaning my range hood and leaning over I somehow set the lock on the cook top. How do I unlock it?
WHAT DO I USE TO CLEAN AN ELECTRIC JENN-AIR CERAMIC COOKTOP; THE BURNT FOOD BUILDUP.
a good product is CERAMABRYTE. it is designed for ceramic cooktops and is a white lotion type cleaner. if there is a lot of burned buildup you may also need to purchase a special scraper with a blade in it. but make sure you smear the cleanser on FIRST or you will scratch the surface.
2answers
I need tips on cleaning my kitchen aid ceramic eletric cooktop.
Use DeBruce Polish. debrucepolish.com. a "True Multi-Surface Cleaner. I guarantee it!!
Top Cooktops Experts
Paul Carew
ADMIN Andrew
ADMIN Andrew
Are you a Cooktop Expert? Answer questions, earn points and help others
