SOURCE: Camcorder stuck in E02 Safemode
really bad tapes maxwell,tdk...good tapes, panasonic,jvc fuji, that could be the problem for these specific camcorders...good luck
SOURCE: Safe gaurd
Safe gaurd mode can mean a number of different problems, most of the time being mechanical, if you are not a tech. you will need to take it in for service.
SOURCE: jvc camcorder
I bouht j.v.c handycam recently, unfortunately lcd screen is broken what is cost ?
SOURCE: My Jvc Compact Camcoder (GR-SXM26EA) is stuck in safe mode
thats a hardware problem .u must to open that camera and remove mechanisum u can c there is a small board behind that mechanisum .remove that board and c there is rubeer which connec to caption motor . that u put right condition than it will work
SOURCE: JVC gr dvl 500U E04...safe gaurd mode/ remove and
Poor contact of drum motor connection(flexi found at the upper part of the drum assy). Solution, disconnect this wire from the connector and cut 1mm from the end so that it will make a new contact. WIre will be shortened a little bit but it still can work this way since this flexi can not be ordered alone, it comes complete with the whole drum assy. Good Luck
