Question about Whirlpool Kitchen Ranges
Whirlpool oven does not work, it's parked out and now is reading F9 on the dislay panel, no buttons work but stove top works just fine
    Novelist:
  • 91 Answers
Oven does not work displaying F9 on the display
GE, Whirlpool, and other brands use this same code for this same issue (door latch fault). You might be able to just clean any grease/buildup from the latching hardware, but it's probably an issue with the mechanism, control board, or wiring between the two.
Posted on Oct 21, 2017
SOURCE:
  • 1073 Answers
SOURCE: oven burnout
replace the oven control
Posted on Apr 25, 2008
aborcass
  • 2651 Answers
SOURCE: My KERS 807 SSS Stove works fine but not oven
sonds like a bad hightemo thermostat, loacted on the back wall behind the rear panel, common issie for ovens ,espessially after going through a self-cleaning,part number 9759242, part is about $50 turn off power before attempting to change, LIVE WIRES!!!!
Posted on Nov 30, 2008
localwonder
  • 6784 Answers
SOURCE: Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Posted on Apr 16, 2009
SOURCE: whirlpool accubake oven troubleshooting
electric oven heats to correcect temp then drops and does not get back too appropriate temp. For example, set at 400, gets there then drops to 275-300
Posted on Dec 25, 2009
SOURCE: water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Posted on Apr 04, 2010
On my new stove i got a F9 code what can i do to get my stove to work
Possibly incorrectly wired. Often these codes are make specific.
F9 or F9 E0 - Whirlpool Home Appliances - Whirlpool® product help
producthelp.whirlpool.com/...Guides/...Ranges/...Code%2C...Code.../F9_or_F9_E0
Apr 22, 2017 - Reset power to the product: This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection. If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply. During a power ...
What does the F9 error code mean on my Kenmore range Model 790 ...
https://www.shopyourway.com/questions/1074065 Apr 6, 2010 - Door locked started blinking, door never locked,..pressed clear button caused "dr" code, pressed clear again and "f9" and beeping occurred. ... This was extraordinarily helpful...we got this oven from my mom in law when our old one died and she bought a new one, we knew nothing about it but thanks to ... How do I get rid of F9 error code on range?
18 Dec 2011
Why does my Kenmore oven display the F9 error code ...
1 answer
29 Oct 2009
How do I reset an F9 on Frigidaire oven?
1 answer
26 Oct 2009
What does the error code F9 mean on my Maytag ...
1 answer
11 May 2008
More results from www.shopyourway.com
going to clean the oven but got a f9 error had to reset it for it to work ...
? 1:49
https://www.youtube.com/watch?v=cgGKxTxxf4E May 17, 2016 - Uploaded by mike webb
going to clean the oven but got a f9 error had to reset it for it to work mike webb po box 408 stryker ohio 43557.
F9 Error Code - Whirlpool , KitchenAid & Kenmore Range - Repair ...
? 1:01
https://www.youtube.com/watch?v=MXMDjZRNDnw Oct 31, 2014 - Uploaded by ApplianceVideo.com
Visit us at http://www.appliancevideo.com Do-it-yourself diagnostic and repair videos brought to you by ...
stove got F9 code Google Search
Mar 18, 2018 | Kitchen Ranges
My whirlpool stove gave me a f9 code and now will not work. How can I fix it?
Oven door lock failure.
Whirlpool Fault Codes
I wouldn't think that this would affect anything other than the oven.
whirlpool oven door lock YouTube
Oct 21, 2014 | Kitchen Ranges
My whirlpool SF265LXTS oven turns on properly, but the oven itself isn't getting hot. The gas stove top and broiler both work fine.
It sounds like you might have a clogged burner plate or manifold. You should call a certified gas repair service. This could be very dangerous, even deadly.
Dec 15, 2013 | Whirlpool SF265LXTS Kitchen Range
Whirlpool electric oven not heating (has a functional stove top)
Hello Daniellel583! We are terribly sorry to hear of your concern with your Whirlpool Range. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, reviewer name (Daniellel583), phone number, street address, zip code, model & serial number, and date of purchase on the appliance. We would be happy to assist you. We look forward to your reply.
Jun 18, 2017 | Whirlpool RF111PXS Electric Range
When I turn my oven on it will only go to door
The problem was the oven microswitch, it needed to be replaced. Now my stove and oven works fine
Jun 21, 2009 | Whirlpool RF378 Electric Kitchen Range
Digital oven will not turn on, I press bake/broil it reads ''Loc''
Look on the control panel for an icon that looks like a padlock near one of the buttons. Hold that button down until it beeps and that should unlock the panel.
Mar 20, 2009 | Ovens
Stove top works oven wont heat on 465
the ignitor needs replacing, that's the glow that you see. it's not getting hot enough to open the safety valve.
Dec 07, 2008 | Whirlpool GS460 Gas Kitchen Range
F9 error
hi there,
can you tell me the model # on your stove please?
Sep 14, 2008 | Maytag CWG3100A Gas Single Oven
Oven burnout
Apr 25, 2008 | Kitchen Ranges
Kitchen Ranges Logo
54 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
