Question about Ovens
My Fridgidaire double wall oven is beeping every 2 minutes while displaying FB. How do I stop the beeping?
    Novelist:
  • 91 Answers
Sounds like an F8 error- problem with the door lock/latch (for self-cleaning mode). Could be the mechanism, control board, or wiring in between. Try unplugging (or turning off the breaker) for 20 minutes to an hour, and plug back in to see if it will reset itself. If you're lucky, you might be able to just clean gunk out of the latch area, but probably need a repair call.
Posted on Oct 21, 2017
SOURCE:
catriver
  • 878 Answers
SOURCE: my older jenn air double wall oven
shooter, F1 is usually the touchpad failure. You can try disconnecting the touchpad ribbon from the control and cleaning the ends with an eraser. See if the F1 stops. Catriver.
Posted on May 24, 2007
SOURCE: Error Code F8
Try http://www.applianceaid.com/fault_codes.html
Posted on Jan 06, 2008
SOURCE: "F1" DISPLAYED AND BEEPING
F1-->Failed Thermistor Control Replace ERC
you will have to replace the ERC or Electronic Range Control or the touch pad.
Posted on Dec 18, 2008
  • 234 Answers
SOURCE: Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Posted on Apr 27, 2009
  • 5 Answers
SOURCE: 326B1230P001 GE Double oven that displays ?F7? and beeps
I have a GE JT950 double oven that just did the same thing: F7 and beeps like crazy. I found solution on another post: an engineer figured out how to solve the issue without calling GE or buying parts. I just did it tonight and it worked fine. Here is a copy of the post:
Send an e-mail to Charlie at hutchipop@yahoo.com for a fix-it that you can try. He explains a possible solution fully with his 'The Dreaded "F7" Error' solution. I actually found his information on another website when I did a web search for "GE Profile Oven F7 Issue". I sent an e-mail to him and he replied with free fix-it information. I am not a repair person myself, but, his instructions are very clear and simple to follow. I did the fix-it at no cost in approximately 10 minutes and it has solved my problem
Posted on Aug 01, 2009
WHIRLPOOL double wall oven has a blank control screen the start button is the only button that beeps
Their is a small in line fuse going to the oven control. Service manual
6b484ffa-e6f8-4c65-aa67-df87a903038a.pngPage 4-2 shows how to get to it. Radio shack has the fuses
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 24, 2013 | Ovens
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
F1 display and beeping
F1 Power to element relay energized during time of day display.
1. Wiring harness shorted.
2. Or change power relay board (PRB).
Note: for double ovens, change second oven board.
Jul 27, 2009 | Jenn-Air JJW8230D Electric Double Oven
F8 Displayed
F1 Electronic oven control failure Replace electronic oven control (also called EOC or clock).
Apr 01, 2009 | Frigidaire 27 in. Electric Gallery Pro...
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Error Code F8
F8 Analog/Digital supervisory Replace clock assembly (also called the ERC)
ohhh thats not good, escpeccially with company coming, replacing the clock appox 175 for part, def wont happen by tommorow nad no you cant separate the 2 ovens both ae wired together
Mar 15, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
Top Ovens Experts
Marvin
Marvin
Sal De
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
