Prowler 12Volt Trolling Motor, Model PRW-FC50/45
SOURCE: Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
SOURCE: Wring for trolling motor
just hook the two batteries up in series. To do this buy one short cable and use it to hook the positive of one of the batteries to the negative pole of the other. Then use the two remaining poles, one positive and one negative to hook up to the motor. good luck
SOURCE: how to install trolling motor
If it is a bow mount model, then you basically need a bow mount bracket attached to the bow of your boat. If one didn't come with the outboard, you will have to buy one from the same manufacturer or an after-market one suitable for your boat. If in doubt, consult the local boating or marine store or wherever you purchased the motor or the bracket from.
SOURCE: how do you operate the motor? I have no details as
The pedal has generally four functions:
1) Forward and back on the pedal make the motor go left and right (push forward to turn the motor right, push back to turn it left)
2) Momentary power - the little 'button' towards the top will engage the motor as long as you press down on it.
3) Selector Swith - on the side of the foot pedeal there is a switch with the following settings Con - Off - Mom (Continuous - keeps the motor going all the time, Off - well it's off and Mom - will only go when you press the momentary button).
4) Speed select - the knob on the left controlls how fast the motor goes.
It takes some getting used to but offers tremendous control and hands free operation!
SOURCE: wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.
