SOURCE: The phone line is correctly connected to the all-in-one but...
To be sure your phone is plugged in properly try picking up a different phone in your home with the fax also plugged into a phone line. The fax display should indicate "Phone off hook".
If the problem still persits, turn off the power to the printer/fax then turn it back on. This reboots the software and usually fixes the problem.
SOURCE: pluged in my phone line and the phone reads Error
Your old phone my have been for a digital phone line. The new phone only works on traditional telco analog. There are adaptors that your phone company has to make the line analog.
SOURCE: "Check Tel Line": Do I need a new phone?
theres some thing wrong with the base unit, try unplugging it and plugging the whole setup at a friends or something, also if youhave a DSL line you my have to install a filter to seperate the data line and voice line. Its ole school but this might work.
I do not have this one but try reversing the plug. I assume other phones work.
However under rare conditions incompatibility between the two machines may cause the remote machine to simply get this code.
Try these steps...
1. Press setup, and then go to TOOLS.
2. Press okay on TOOLS, then look for RUN FAX TEST. Then press okay.
3. It will print a fax test page. Check if everything passed.
4. If it passed everything, try to press setup again, and then go to ADVANCE FAX SETUP.
5. Scroll, down and look for ECM (Error correction mode), then press okay
6. Under ECM you will have to options "ON or OFF" try to choose OFF then press OKAY.
7. Now, try sending a fax.
Also you can try to reset the printer.
1. Take out the cartridges from the unit .
2. Make sure the unit is connected to the wall jack directly without any surge protector.
3. Unplug the power cord from the back of the unit ( without turning off the unit ) .
4. Now press the # and 6 key together , while holding these keys down plug in the power cord back into the unit .
5. Do not release the keys after a few seconds you will find the hp logo or bars moving across the screen .wait while the unit turns off.
6. After one minute turn on the printer . It will go into alignment phase > let it finish .
7. After its done > try to make a copy .
Note - you can also try the OK and CANCEL key combination in place of # and 6
