There's now such thing as "a" wiring diagram. Read this post on the info you need to get the right diagram
http://ricksfreeautorepairadvice.com/get-car-wiring-diagram/
How to get car wiring diagram Ricks Free Auto Repair Advice
SOURCE: need a wiring diagram for mitsubishi cordia turbo
give these websites a try www.alldatadiy.com and www.autozone.com if all fails stop by your local library and get your hands on a Haynes auto repair manual for your car wish you the best of luck Michigan Man.
SOURCE: BMW X5 CAMSHAFT POSITION SENSOR A .SHOW DIAGRAM
hi i have a diagram if you would like it i could email it to you and there are 2 of them does it say which one it is? you can email me at
[email protected]
and i will send you the diagram hope this helps
SOURCE: How can I get a fuse box diagram for a bmw x5 4.4i
my bmw has the diagram in the fuse box, try that first
SOURCE: Have a 2004 registerd 3.0 litre diesel BMX X5.
there is a breather for the turbo placed on top of the rocker cover this should be changed on service failure to change it causes it to block up and put pressure on the turbo causing it to go make sure filter is changed if u replace the turbo
SOURCE: My BMW X5 is blowing
check the emission system on ur bmw once and then if it doesn't help get a new one.
