Microwave Ovens Logo
Nora Leos Posted on Oct 18, 2017
How can I unlock my lg microwave lcrt2010st, I have tried holding down the start button and it does not work.
3 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Aug 19, 2008
SOURCE: Sharp R-1450 microwave
This is usually caused by either a bad door switch, a loose door switch mount, or occasionally a problem on the control panel.
On these, it's usually a broken tab on the upper switch holder.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
That sounds like what's happening when you hold the Start pad - maybe you're moving the frame and chassis enough to help it work.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
William E. Miller
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Dec 07, 2009
SOURCE: The microwave oven start button does not work. If
You probably have a bad door switch or door switch mount and should see these files:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
If it's not the switch or mount, you may need to adjust the door alignment.
If you still need help, to allow us to help you effectively (at no charge), please post a NEW problem to FixYa, and please include your brand name and the full model number from the tag in or on the unit, and requote your symptoms, as you posted previously.
Anonymous
  • 2299 Answers
  • Posted on Jan 19, 2011
SOURCE: The start button, light and vent buttons do not
This sounds like a control board issue.
How can we get the clock display to remain on continuously please? LG microwave Model LCRT2010ST
If the display comes and goes the only fix is to replace the complete control panel, a very expensive part.
I have replaced a thermador MBBS microwave with an LG lcrt2010st. Thermdor has a couple of pieces like baffling on the top going down behind the unit and another on the side. These seem unnecessary. My...
I just successfully replaced a Thermadore MBBS microwave with an LG Model #LMC2075ST (Lowes stock number 728040). It was close to a perfect fit into the Thermadore trim kit and attachments, and very easy install. The LG was only $169 on sale at Lowes, and is, by far, a superior microwave to the old MBBS model.
The turn table goes on when u open the microwave
Obviously someone has worked on this unit and wired the wrong wires to the door microswitch
Lcrt2010st turns on with door open
switch is faulty at inside could be burnt
Can't unlock kennmore microwave, tried the start, stop/clear button it does not work
holding the stop / clear button for 5 seconds or the start button for 5 seconds usually works,
see this link
http://www.fixya.com/support/t8306273-unlock_digitals_butons
3helpful
How do i unlock my lg microwave i dont have an owners manual so i dont know how to unlock it
"Locked" meaning the buttons don't work/non-responsive (Child Safety Locked)? To Unlock/Disengage the Child Safety. Push and hold the "Clear/Off" button for 3 to 4 seconds. The Child Safety is disengaged - problem solved.
21helpful
5answers
My microwave is locked and i dont know how to unlock it
"Locke" meaning the door? or locked meaning the buttons don't work? If it is the buttons then you have the child lock on. Push and hold the "Start" button for 4 to 5 seconds, and it will unlock.
Top LG Microwave Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
