SOURCE: RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
SOURCE: I have a Westinghouse 26 inch TV.
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
SOURCE: Viore Remote Control Codes for Direct TV
Contact service provider ( ie Directv.) to see if they have the code or a scanning method to get it to work.
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
