Computers & Internet Logo
c
cory carter Posted on Oct 18, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hello I have an acer tablet with windows 10 and its been stuck undoing changes for about 4 days how can I get in to restore it
NOEL
Level 3:
Top Expert:
  • Acer Master 8,606 Answers
  • Posted on Oct 25, 2017
NOEL
Acer Master
Level 3:
Top Expert:
Answers
8606
Questions
18
Helped
2322249
Points
68630
Try this link might help. Step 1 Acer Iconia Tab B1-711 3G - Factory / Hard reset / Password Removal
  1. Power off the tablet. Press and hold the Volume Up and the Power button. ...
  2. [SD Image Update Mode]
  3. wipe data/factory reset.
  4. Yes - delete all user data.
  5. Reboot system now.
  6. Your tablet will reboot and go to the Welcome screen.
Acer Iconia Tab B1-711 3G - Factory / Hard reset / Password Removal ...
https://www.ifixit.com/Guide/Acer+Iconia+Tab+B1...Factory...reset.../23792 acer tablet restore to factory settings Google Search
1 Related Answer
Azrael SRL
  • 11800 Answers
  • Posted on Feb 26, 2011
SOURCE: Hello my Acer aspire one
One of the drivers or programs that is set to launch during boot is corrupted. You will have to find out which and uninstall / upgrade it.
Boot in Safe Mode, click Start, Click Run and type msconfig and hit enter - the startup management window will launch. Click on the Startup tab and untick all the programs in there. Now reboot. If you get the same error then the problem is with a driver - uninstall them all then download the latest versions from the Acer Support site and install them one by one. If the problem is fixed then one of the programs is corrupted - open msconfig / Startup again and tick one program at a time with reboot until the problem returns: uninstal that program.
tip
System Restore
Use System Restore to Undo Changes if Problems Occur
Windows XP Professional makes it easier to resolve problems if they occur in your system. You can use System Restore to remove any system changes that were made since the last time you remember your computer working correctly. System Restore does not affect your personal data files (such as Microsoft Word documents, browsing history, drawings, favorites, or e–mail) so you won’t lose changes made to these files. Windows XP creates “restore points” every day, as well as at the time of significant system events (such as when an application or driver is installed). You can also create and name your own restore points at any time. Creating a restore point can be useful any time you anticipate making changes to your computer that are risky or might make your computer unstable. If something goes wrong, you select a restore point and Windows XP undoes any system changes made since that time.
When you run System Restore, a calendar is displayed to help you find restore points. If you don't use your computer every day, some days might not have any restore points. If you use your computer frequently, you might have restore points almost every day, and some days might have several restore points.
To create a Restore Point
1. Access the System Restore Wizard through Help and Support Center. (Click Start, and then click Help and Support. Click Performance and Maintenance, click Using System Restore to undo changes, and then click Run the System Restore Wizard.
2. Click Create a restore point, and then click Next.
3. In the Restore point description box, type a name to identify this restore point. System Restore automatically adds to this name the date and time that this Restore Point is created.
  • To finish creating this restore point, click Create.
  • To cancel restore point creation and return to the Welcome to System Restore screen, click Back.
  • To cancel restore point creation and exit the System Restore Wizard, click Cancel.
To view or to return to this restore point, from the Welcome to System Restore screen of the System Restore Wizard select Restore my computer to an earlier time. Then select the date when the restore point was created from the calendar in the Select a Restore Point screen. All of the restore points that were created on the selected date are listed by name in the list box to the right of the calendar.
To set advanced restore options
1. Open Backup. (Click Start, goto to All Programs, point to Accessories, point to System Tools, and then click Backup.) The Backup Utility Wizard starts by default, unless it is disabled.
2. Click the Advanced Mode button in the Backup Utility Wizard.
3. Click the Restore and Manage Media menu and select the files to restore.
4. Click the Start Restore button.
5. On the Confirm Restore dialog box, click Advanced.
6. Set the advanced restore options you want, and then click OK. See the Notes section for a description of each option.
on Dec 01, 2009 • Computers & Internet
My acer is stuck in the Windows xp screen and wont start up, I had turned it off and restarted it get to safe mode screen, but had not helped.
When you restart your laptop, keep pressing F8 until you see the "Windows Advanced Options Menu:"
Then choose "Last Known Good Configuration".
This will restore your computer to a previous configuration and might undo some changes you did to your computer before the problem happened.
2answers
I have an e machine, and card just quit recognizing my camera card. Don't know if I deleted a necessary file or what..
if u deleted it just use the windows restore sytem option , or download the driver of what ever it lost at acer
My acer travelmate 2420 is not booting. i just loaded pics from camera to print, it hang and now everytime i boot windows just keeps restarting over and over. what do i do?
Press F8 during boot this will take you to boot options select "Last Known Good Configuration" or select Safe Mode to perform a system repair.
To repair your system follow the steps below
1. Click Start and open Run on the Start menu.
2. Type (or copy and paste) C:\WINDOWS\system32\restore\rstrui.exe in the Run box.
3. This will open System Restore now select the first option (restore my computer to an earlier time) and click next.
4. Select a date when your network last worked and complete restoration.
Do not worry about selecting the wrong date you can always undo any restore within system restore you will select undo last restore.
My camera isn't working i having done anything is
To, perform a System Restore! is the best option; it will “restore the system” back to a previous state, to undo the change. 1. Go, to: Control Panel. 2. Click System and Maintenance. 3. Click Backup and Restore Center. 4. In the (left), Tasks area click on Repair Windows using System Restore.” 5. The restore Wizard appear. 6. Choose (Recommended) Restore Point. 7. Follow all instructions thereafter. *Note: Once the computer returns to Windows Desktop, do not perform any tasks, for at least (45 min) the System Restore is still running. I hope this Fix it.
My HP Mini 1000 XP will not restart, it gets stuck on the Windows XP welcome screen
How to restore computer during boot up?
1helpful
2answers
Can We Change the graphic Card of Acer TravelMate 4102 WLMI
On laptops the graphics are built in onto chips that are on the motherboard, in order to change to the graphics chip you would have to upgrade to the motherboard to something that acer might have.
Missing files and photos, settings ect
Log in as Administrator and undo the system restore.
How to undo a system restoration after you perform a System Restore loadTOCNode(2, 'moreinformation'); You may have unintentionally restored Windows XP to a previous configuration that you do not want. To undo the restoration, follow these steps:
  1. Log on to Windows as Administrator.
  2. Click Start, point to All Programs, point to Accessories, point to System Tools, and then click System Restore. System Restore starts.
  3. On the Welcome to System Restore page, click Undo my last restoration, and then click Next.
    Note A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
  4. On the Confirm Restoration Undo page, click Next. System Restore restores the original Windows XP configuration, and then restarts the computer.
  5. Log on to the computer as Administrator. The System Restore Undo Complete page appears.
  6. Click OK. You can now run System Restore again from a different restore point.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
