Better to talk with dealer directly as they can tell you the exact solution for it. I also using a watch which made from woods and when I need anything then I use direct contact with watch provider as "Lux Woods"
Seiko 5N0313 refers to the movement fitted inside the watch - it's not the model number of your particular watch.
Go to
https://www.leaf.tv/articles/how-to-find-a-seiko-model-number/
where there should be enough info' to allow you to determine the model number, then do a search based on that number.
SOURCE: How much is the capacitor problem in Seiko SNL001
Can be fixed in less than one week and cost is less than $80. See web site for Timelywatch repar.com. They guarantee their work. And yes, the old capacitors are only good for 3-4 years. All replacements are now with a much better, long lasting Lithium Ion battery.
SOURCE: Previously accurate Seiko dive watch suddenly gaining 1-2 hrs/day
if your watch caliber is 7s26b(look at the case back plate)is a usual problem of those calibers!the hair spring stuck somehow and the watch runs!a seiko authorized sevice center can help you!dont let anybody else magician to ruin your watch!is a routine repair for someone with knowledge and support from seiko!
SOURCE: the rubber band broke on my seiko dive
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
SOURCE: men's seiko perpetual calendar watch stopped
mcdevito75 here, Your Jeweler had to mention your watch would go to Seiko for repairs. Seiko should notify you or your Jeweler with the repair particulars.
SOURCE: manual for seiko mens automatic
The retailer is supposed to provide an instruction booklet with the watch. If you do not have one, please contact the retailer from whom you purchased the watch. If that is not possible, please contact the nearest Seiko Service Center shown on the Seiko world map. In addition, features and operations as well as instruction manuals for some calibers are available below.
http://caliber.seikowatches.com/
Good luck
