2005 Kymco Movie XL 150 Logo
Keith Knight Posted on Oct 17, 2017
How to remove the rear wheel from a Kymco Movie 150@
2helpful
Kymco Movie 150. It just turns off when I come to a stop, as if I hit the kill switch?
Unlikely to be electrics. More likely fuel delivery. See if the fuel pipe run close to something very hot like the exhaust or the engine cylinder or cylinder head. I have seen airlocks that stop fuel after 10 minutes.
It appears to be a known issue. There are some other ideas.
https://www.google.com/search?q=kymco+movie+150+stalls+when+driving
I have just bought a new kymco racing 150 fi and find a slight hesitation when a constant speed. Acceleration is fine. also after a ride out then back home the engine turned off i get a crackle noise from...
when you go for the 600 mile check up, tell the dealer the crackling noise is expanding and contracting of new exhaust , and change the oil dino oil for the first 1500 miles, then you can change to full syn., and change the oil hot after a good ride
Remove and install front forks kymco 2009 people 150
Strip out front wheel assembly remove front plastic's up inside are two bolts per side remove them drop out forks refit in reverse order.
Remove rear wheel
what exactly is the question? removing the rear wheel is kind of straight forward on that little guy.
Remove rear wheel
You need an air ratchet gun to remove the wheel's bolt but alternatively you can use your rear brake to hold the wheel still and use a plain ratchet.After you have loosen the wheel's bolt, remove the exhaust and the rear brake caliper and the wheel is out.
Top Kymco Experts
Arnie Burke
Arnie Burke
littlewheel
Are you a Kymco Expert? Answer questions, earn points and help others
