Tools & Hardware - Others Logo
D
David Marchant Posted on Oct 17, 2017
Hercus 260 ATM lathe what is shipping weight please
1helpful
I would like to know the dry weight of a Victor CMD 484 self propelled lawn mower please.
dry weight isnt normally added in specs
it would be printed on the outside
on the shipping crate or mower box the mower came in
try to contact victor via ...email that question
Contact Us Victa Lawncare Lawn Mowers Outdoor Vacuums Edgers7f24d8d0-fc94-44ea-a6c3-5bebcdfe88cf.jpg
Sep 02, 2016 • Garden
Ammco 4000 longtravel g/box adjustment not working properly,variable speed adjustment works slowly,then when increased starts to work backwards
What you are referring to is called an "Infimatic" gearbox, or drum-feed gearbox.
The problem lays inside most likely with the clutches.
They are worn out, and possibly other components are worn and broken. Feeding backwards means something has gone terribly wrong--and it needs to be fixed immediately for the machine to operate properly.
These gearboxes are not easy to fix properly--they are literally like a puzzle inside. Our shop employs a infimatic gearbox specialist and we are one of the few shops who can rebuild them to factory spec.
A brand new Infimatic gearbox will run you over $1,300.00 plus tax and shipping from an Ammco depot.
You can ship a broken Infimatic gearbox to our shop for a complete rebuild to factory spec.
For more information...
Buy Sell Used Brake Lathes Brake Lathe Parts
2answers
What is the weight of this unit?
product weight is 149 lbs and shipping weight with box ect....would have been 174 lbs hope this helps you lol
1helpful
3answers
Brake lathe chattering bad
There's a lot of reasons why a brake lathe chatters during a cutting operation. They range from lack of maintenance, adjustments, cutting speeds, wrong cutting tools and so on and so forth.
Be a little more specific.
What kind of machine are you using?
What are you cutting? (rotors? drums?)
Are you using the proper silencers?
Come back with some answers please.
I wish to put a smaller flywheel to my dt 400 yamaha can you sugest one?
Just take your standard flywheel into a motor shop that has a lathe and tell them how much weight you want taken off.
What are the specifications for this drill ?
The specifications for the drill are.
Capacity: Steel 3/8''
Wood 1''
No load speed: Low 0 - 400 RPM
High 0 - 1,300 RPM
Maximum torque 260 in.lbs.
Battery 14.4VDC (1.3Ah)
Length 7-9/16''
Net weight 3.5 lbs.
Shipping weight (6281DWPE) 9.4 lbs.
(6281DWPLE) 10.7 lbs.
Master carton qty. (6281DWPE) 5
(6281DWPLE) 4
UPC Code (6281DWPE) (088381-092067)
(6281DWPLE) (088381-092128)
Or you can go to the link below to get all the specifications plus the manual.
http://www.makita.com/en-us/modules/tools/ToolDetails.aspx?ID=974
Good Luck please rate 4 thumbs up and please leave a testimonial
I am thinking of buying used kenmore model 110.49722992. I live in an RV, and I need to know what the "empty" weight.
Please see the following Sears Parts list and Owners Manual.
The loaded weight is 260 Lbs.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.49722992
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0710496.pdf
Water is 8.35 pounds per gallon. Plus the weight of your clothes.
Top Tools & Hardware - Others Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
