SOURCE: peg-perego John Deere buck EXT reads fully charged, but won't go.
I would replace the high/low switch and the reverse switch.
You can get the peg perego parts at http://www.shopjandl.com/
but I would first check the connections on the motors and foot switch. Sometimes they come loose.
Hope this helps
SOURCE: No spark
did you make sure the gap was set right on coil & flywheel it should be .020 between magnet on flywheel & the coil & the same thing with the points in the open possition between points & condensor
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
SOURCE: wire diagram 2005 john deer 500 buck atv
I have the same exact problem for my John Deere Buck too...Any solutions out there? I have disconnected and reconnected my speedometer head and still dead.
Testimonial: "thank you so much for your help , althogh i tryied time after time and got no good luck from joihn deer dealers. and now im not really impressed with ther service of knowlege with their product that sell not a good way to their customers . KEEP UP THE GOOD WORK . MY PROBLEM WAS THE SAME AS YOURS AND NOW ITS CORRECTED THANK YOU AGAIN. JOHN MENARD "
SOURCE: JOHN DEERE LX172 has no spark replaced coil still no spark why?
take the wire that goes to the coil off and try it if you have spark with the wire off the problem is with a safety switch or wiring
