SOURCE: how do I descale the saeco magic deluxe coffee machine?
Try this:
Standard descaling
Switch off the machine.
Pour a descaling product into the water tank.
Switch the machine on to the programming mode(see below). Place a large container under the steam/hot water dispensing tube and open the steam/hot water knob slowly, turning it counterclockwise.
Turn on the machine by pressing the main switch and let the descaling product flow out of the dispensing tube for approx. 1 min.
Close the knob again.
Turn off the machine with the main switch and let the solution take effect for approx. 5 minutes.
Repeat this procedure two or three times, to allow all of the descaling product in the water tank to flow out of the dispensing tube.
As soon as descaling has been carried out, rinse the tank thoroughly and fill it with fresh water.
Switch on the machine and let fresh water (approx. 2 l) flow out of the steam/hot water dispensing tube in order to rinse away residue.
The machine is now ready for operation.
When the machine is on, the warning light switches off automatically, by pressing the steam selection button for at least 5 seconds.
To enter the programming mode, turn the machine
off with the main switch.
Press steam , espresso coffee and the
main switch at the same time.
Release the buttons.
Hope this will help you.
/Mirran
SOURCE: the red light for descaling won't go off after descaling
The button to push was the steam button and hold for 5 to 10 seconds until the light goes out.
SOURCE: I have descaled my Saeco Odea and the coffee beans
Hi, Try holding down the steam button for 10 seconds. It should reset the descale warning lamp.
Hope it helps.
Andrew
SOURCE: I Have descaled my Saeco Odea Go but still it doesnt brew coffee
That is serious, that means the grinder is jammed or not working. To check the components of the machine follow these instructions.
Press and hold the steam button and turn on the machine, when you see the lights going around in anticlockwise direction, release the button. Turn the coffee dial to the left and press the steam button, the grinder should turn. Dial on the right and pressing coffee ****. water pump runs. Press steam ****. brew group go up, dial 1/4 to left B/Group down.
If grinder not turning the motor is bad. Hope it will help to find out.
SOURCE: Magic Comfort Plus Espresso Machine: how to descale saeco magic comfort...
