Https://www.abctay.com Wholesale TV Power board,cheap,and good quality,Provide 3 months warranty,support dropship,Support single purchase
Abctay.com is an online shop ,
We sell television and electrical accessories,all kinds of TV power supply board, logic board, TV LED screen,
TV LCD screen, mobile phone screen, as well as various types of electronic tools,tv parts power supply,LCD,ccfl ,
LED,OLED,lcd panels,HMI,Inverter,LCD screen,lg screen,display screen,lcd monitor,lg lcd, lg monitor ,flat screen ,
touch screen,hmi,bulb,samsung, innolux ,Mitsubishi,philips, hitachi,auo,innolux,Planar, toshiba, siemens,chi mei,Weinview,
Infineon,industrial LCD,industrial control, sharp monitor,vigor plc,delta, mitsubishi lcd,omron plc,etc. Abctay com China Wholesale Wholesale Electronics Gadgets tv parts power...
Testimonial: "This comment was not helpful. There was no troubleshooting tips or any idea what may be wrong or how to fix. All this says is buy this part... Not helpful..."
SOURCE: nothing but snow
Your explanation about a different TV receiver working OK on the same aerial connections leads me to believe you have lost the tuning in the faulty receiver...
Just "snow" with no sound is a classic response for lost tuning....
It shouldnt have lost the tuning as there is a small battery(capacitor) that holds the previous receiver channel settings when you turn the TV off. But as you have had the Receiver in the back of a truck and disconnected from the power supply for some time then this is probably the culprit....
This battery (Capacitor) may be getting old and has lost its capability of sending a minute amount of current to the tuner IC (Chip) ...to hold your previous channel settings...So if you can retune the receiver to the output from the Dish Network Receiver you should be fine again, but if the battery is shot you need a new one....or just leave the Receiver in the standby mode for a couple of days to re-charge the battery (capacitor) up.
You will need a service technician to replace this small battery (capacitor) its a special type made just for your receiver....
Hope this helps
YUBEUT..
SOURCE: NO POWER AT ALL!
Does the power supply have its own power switch?
It is located next to where the power wire plugs into the back of the PC.
SOURCE: dell 725 wont work
Hi aliciaa
I think you just need the installation or setup instructions for your printer. I suspect something is simply unplugged or similar.
HERE you will find Dell's manual for their Photo AIO (All In One) 725 personal inkjet printer.
HERE you will find Dell's page for trouble-shooting problems related to your printer.
HERE you will find all the drivers and downloads related to your printer on Dell's web site.
Make sure that there is a cable going from your printer and plugged into your computer. Make sure the cable is fully "seated" (plugged in completely) on both ends (at the printer and at the computer.)
One other cable should be coming from the printer. That cable will be A/C power cable. Make sure it, too, is seated properly (fully plugged in) at the printer and at the A/C outlet you are using for it.
If the power cord is in two parts (one w/ a "block" on it), make sure that the two segments are joined together completely. The segment of cord w/out the block on it will plug into the "block". Make sure it is seated in properly as well.)
Finally, make sure that the outlet that you have the printer plugged into is working. (Plug a lamp or something similar into that same outlet and confirm that you are able to turn on the lamp.)
Please, let me know if this response was a "FixYa"
or "Helpful" for you or, of course, if you have
any additional questions, etc on this topic.
If the information I provided you w/ resolved your
problem or lead you to a resolution for your
problem or an answer to your question, then, a
"FixYa" rating would be most appreciated. @:)
It is best to wait until the problem has been
resolved b4 scoring the experts who participated in
solving your problem or answering your question.
(Once you enter a rating, the problem will be
closed and we will not be able to continue to assist
you.)
Very often it will take more than one exchange of
information between you and an expert in order to
resolve your problem. If a proposed solution
doesn't work for you, don't rate it yet. Instead,
post back here letting us know and we'll continue to
work w/ you until we find a solution that does work
for you.
Thank you
BJ @:)
SOURCE: XBOX 360 won't work.
This is for EVERYONE.
You've had a hardware failure. There are 3 major causes for failure on these units:
1) Cold Solder joints - this means that the soldering done on the main PC board, was done incorrectly and as such the solder is not adhering to their contacts properly. They are prone to cracking, and other inconsistencies which will cause improper function
2) Lead Free Solder used - Lead Free solder is good, but the quality used by Microsoft is horrible. They used the cheapest and crappiest lead free solder they could find. Read #3 for the reason why this is bad...
3) Inadequate Ventilation - The XBOX 360 get's extremely hot, and when this happens, the lead free solder used on the pc boards will start to become weak and crack - in addition to reason #1
Because MS rushed to production, and did not properly test and assembly these units, hardware failure is imminent.
You will need to take to a qualified service center for repair. MS offers a 3 year warranty on the infamous "3 Rings Of Death" issue, if it is something else, then there is only a 1 year warranty.
MS does offer Free shipping, and includes a 1 year warranty after the repair. However, we've heard stories of the MS NOT fixing the problem, and sending back units with the same issues, or worst. Also, expect to be without your Xbox for at least 6-8 weeks. If you do not have a warranty, the cost is $99 for the repair from MS.
Good Luck everyone!
- Davis
Digital Analog Therapy
www.REPAIRNYC.com
SOURCE: I moved this TV to another room about 10 days ago
You probably have a bad Main bd and needs to be replaced. Contact 1-800-SAMSUNG for the part number or have a trained Samsung tech repair the set.
Our tv is a Visio E322AR. Do you have any suggestions to trouble shoot? We ran through all the things we could think of...
