Microwave Ovens Logo
Claudia Gathercole Posted on Oct 15, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Owners manual for a GE Spacemaker over the range microwave model #JVM1440WH01
Level 3:
  • GE Master 6,688 Answers
  • Posted on Oct 15, 2017
Cindy  Wells
GE Master
Level 3:
Answers
6688
Questions
0
Helped
3532760
Points
21745
GE has the manuals for most of their products on their support site: http://www.geappliances.com/ge/service-and-support/literature.htm?icid=GEARsupportflyout-manuals . The direct link to the Owner's Manual for the JVM1440WH01 is currently https://www.myapstore.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40473.pdf . This particular model's support page is https://www.geapplianceparts.com/store/parts/assembly/JVM1440WH01 .
I hope this helps.
5 Related Answers
Anonymous
  • 4 Answers
  • Posted on Nov 29, 2007
SOURCE: Removal of GE Spacemaker Microwave oven
1. Unplug the microwave. The plug is probably in a receptacle that is in the cabinet above the microwave, or in the wall above the shelf that is above the microwave.
2. Remove the two (or three) screws that go straight down through the bottom of the cabinet, or the shelf, into the top of the microwave. Have help in holding the microwave when you do this, as the front of the microwave will be able to fall down when the screws are removed.
3. Allow the front of the microwave to rotate down a little, then lift the back of the unit up about 1/2" to 1". At this point, the microwave will be disconnected from the mounting plate on the wall, so you can move it forward and carry it away.
robert landry
  • 96 Answers
  • Posted on Jan 22, 2008
SOURCE: ge spacemaker microwave jvm/1650
Mmmm it's so easy,
First disconect the power, take the cover off, moslitly there would be 5 screws and two tab's on the top.
inside on the right hand side the magnetron it's a sylver box measuring about 4 in x 4 in x 5 in. It will have a plasic cover moslitly that would have to be remove first then on the magnetron there is 4 crews and one connector.
It should fall downard after.
If you have a power supply after the secondary , that may also be your problem.
Regards
Bob
tiway1
Tim martin
  • 100 Answers
  • Posted on Jun 30, 2008
SOURCE: Need down loadable manual for PVM1870 DMCC GE Profile Spacemaker XL1800 over the range micro.
Follow this link to GE's manual download page and type in your model number ...
http://www.geappliances.com/service_and_support/literature/
vitg55
Vitaliy Gins
  • 78 Answers
  • Posted on Dec 15, 2008
SOURCE: My Ge SpaceMaker XL1800 Microwave Oven won't power on any more.
1.Check power outlet for working.
2.If it is than you have broken fuse inside the m/w.
3. To change the fuse you have to disconnect the power to m/w, take the upper grill off, take the screw on top of control panel, lift the control panel up and removed. The 20 Am fuse located behind this panel.
I’m happy to help further over the phone at https://www.6ya.com/expert/vitaliy_f406165329c75ede
Anonymous
  • Posted on Dec 24, 2008
SOURCE: I need an installation guide for a General Electric Model JVM130K
I have the same model and the instructions at this site on how to remove it will help you. The owner's manual is useless. Good luck!
Need installation/ owners manual for GE microwave model #JVM1440WH01
Just go online with the brand, name of product, and any model information and it should be found!
Space maker JVM1440WH01 sounds like it is heating, turntable turns light works, but food does not heat???
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
0'''''''''''''
Need installation instructions and owners manual
You can download GE owner's manuals and installation instructions here.
1helpful
Spacemaker 2.0 panel is locked.
Hi.
You can unlock the oven holding down the CLEAR/OFF button for 10 seconds, until the panel reset.
If that does not work, then there may be an internal fault , in that case call GE at the number listed on the owners manual.
Usually reset by holding the button will fix the problem.
Regards.
Rudy0819: My GE Microwave Spacemaker model JVM1440WH01 just stopped heating. I used it earlier and it worked fine. When I went to use it again, it won't heat. Everthing else works, the light, fan, etc,...
The most likely thing is the magnetron has 'died' but there is a high voltage fuse between the capacitor and the magnetron which may blow. Either way, repairs to microwaves are dangerous and should only be undertaken by a qualified repairer. PS I have seen a mouse cause this problem!
Model of 1989 GE Spacemaker
The model number should be on a tag as shown in the drawing below.
No instruction manuel for model J VM152H 002 (was installed when we moved_
The Owners Manual for the GE JVM152H can be found, saved, and printed from this page: Owners Manual
Hope this helps!
1helpful
Model Jvm1440wh01
There should be a flame sensor (aka oven thermal cutout or TCO) located on the top left side or corner of the chassis.
You will have to remove the outer cover to find it.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
