THE REAR TERMINALS DONT WORK
@Michae Yokeum
"Rear Speakers on Pioneer VSX-401".
Hi Michae.
Wow, nice Hi-Fi!! :) :)
IF [manual_required] THEN
GOTO
https://www.pioneerelectronics.com/StaticFiles/Manuals/Home/VSX-01TXH_OperatingInstructions0523.pdf
ELSE
Check your SBch* setting which should be set to ON or AUTO.
*Speaker Back channels
More info on pg. 83 of manual.
PS - as this is a home hi-fi and not a car-radio, I've moved it from 'Cars & Trucks' to a new home 'Audio Players../Pioneer', where experts in that field can offer more help.
SOURCE: connecting 2 stereo amplifiers using one as a preamp and the other as a booster
I would take from the tape out of the pioneer and feed into the aux input of the marantz you will then have to adjust the volume levels on each amp as required
SOURCE: Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
SOURCE: Pioneer vsx-5300 reciever
If you have just one pair of speakers hooked up and have both A & B speakers selected you won't get ANY sound out of unit, so check that?
SOURCE: Pioneer vsx-d902s
Hi Tracey
Most of these older machine had speaker switches on the front panel. Can you check what they are set to. It may be that both switches(A and B) are set in, or set out. this could present the problem you are having with no sound. turn on just one switch that corresponds the connections you have made on the rear (use speaker A) Another thing to check, is when you first turn on the amp, do you hear a relay click shortly after you switch on. If you don't hear this delayed click, then there may well be a problem in the output stages of the amp. If this is the case, then you will need to take it to a tech to have a look and see what has failed in the amp. Hope this info helps, if you have any questions, I am happy to try and help you further.
regards
robotek
SOURCE: pioneer vsx-519 no sound from center and surround
Make sure that the sound field/programme you have selected is dolby digital not stereo.(On the amp)
You also need to check on the display that is says DIGITAL not ANOLOUGE, as only a digital input, Optical fibre cable, HDMI, COAX will be a digital signal.
If you are using red and white rca connectors, it is not going to work, as this is an Anolouge signal.
