Televison & Video Logo
A
Anonymous Posted on Oct 15, 2017
How do I change my Samsung ps50b450b1dxxy TV from ATV TO DTV and how do I retune it without a remote
Can some please help me out my Samsung tv is stuck on ATV how do I change it to DTV and how to retune it without the remote tryed to do it by the buttons on the tv tho not sure which button OK did try menu but it straight back thr main screen can anyone help me plz had no tv for days
I have an old samsung tv, working perfectly. I have hit a button on my remote and it now is on atv mode and not digital. Help please
Hi Sue, try selecting with the Source or TV button on your remote control, if you can return to the DTV position
you must go through the different inputs and at some point the DTV option should appear
Indicate the model of the Samsung you are commenting on, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Sue, prueba seleccionar con el bot?n Source o TV, de tu control remoto, si puedes regresar a la posici?n de DTV
debes pasar por las distintas entradas y en alg?n momento deber? aparecer la opci?n DTV
Indica el modelo del Samsung que estas comentando, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
Very old samsung tv. I have hit a button on my remote and its now atv not dtv. Help please
I wait your answer
Hola Sue, prueba selecionar con el boton Source o TV, de tu control remoto, si puedes regresar a la posicion de DTV
debes pasar por las distintas entradas y en algun momento debera aparecer la opcion DTV
Espero tu respuesta
1helpful
I have a toshiba lcd tv without a remote and want to change between dtv and atv anyway to do this without the remote?
Hi u don't mention model of tv .
if you're tv is fitted with a full set of control buttons u CAN..check if it's got a menu button it's a bit involved but u can do it good luck
2helpful
I cannot retune my samsung tv- model no LE37C53CF1W- COULD YOU ADVISE HOW TO RETUNE, mANY THANKS, Jim Lauder
Hi,Does the icon look like a large satellite dish?
Make sure your TV is on "TV" and not "DTV" before retuning.
To re-tune analogue channels:
I have a Samsung TV and that icon is not accessible from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
(on your remote, you should have a button with TV/DTV on it)
To re-tune analogue channels, if you want to re-tune digital channels, then look for the "D MENU" button on your remote. Press this then scroll down to the icon that looks like a large satellite and then on "Auto Store" This will re-tune your digital channels :0)
Take care and hope it helped.
Could you please advise if our model Samsung TV. LE26R8 purchased in 2007 has the built in FREEVIEW tuner. Many thanks, Peter smart
Yes it does.
If you look on your remote there should be a dtv/atv button and a dtv menu button to tune it into dtv.
17helpful
2answers
99helpful
2answers
I am trying to re-tune my Samsung DV3 HD TV for the switchover but when I try to select settings it won't let me click on the icon to re-tune the TV
Does the icon look like a large sattellite dish?
Make sure your tv is on "tv" and not "dtv" before retuning.
I have a Samsung tv and that icon is not accessable from the menu if i am watching the tv on the digital option of my remote. You have to switch your tv to the "tv" option on your remote and you will be able to access the icon from your menu.
154helpful
5answers
HOW DO I RETUNE MY IN BUILT FREEVIEW ON A SAMSUNG LCD LE40R73DDX 40'' TV. PLEASE ITS VERY URGENT
find the ( d menu ) button on your remote then select ( chanel ) option then select ( auto store ) and press entter ! job done
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
