It has 4 separate on-off A,B,C,D The problem is they won't switch on and off separately. Is there a way to reset them back to factory settings and start again. Bought them from Bunnings.
Unplug switch, plug in and while the LED is flashing, press and hold the All/turn off button. The LED will flash quickly, then it's unprogrammed when you plug it in again.
(This is in the instruction sheet, BTW)
Thanks. Solved my problem first go.
Best ever! Fixed!
You are a gifted human. Fixed & Thank You
I don't have the instructions anymore, so this is very helpful and works, Thanks
BTW I have 4 receivers and two remotes from a set of 3 and a single set. I now have all working on one remote which is great, but the other remote does nothing, do you know if I can program the second remote to also use the frequencies of the other.
SOURCE: Printer Problems LEXMARK 5100 Series - 5150 model
this link will help you ...
http://www.lexmark.com/publications/pdfs/techref_WB.pdf
Thanks for using Fixya
SOURCE: MAXDATA Laptop Model Number L55110 reset factory settings
Reset the cmos (bios) by taking out the lithium battery (obviously disconnect from power first) and leave it for 10 minuets. You will need to reconfigure the settings in your bios afterward. If you still have the problem you will have to look to hardware problems, which could be various ones.
If your unit is displaying DVD2 on the front panel, you will need to set the command on the remote to match the display on the unit.
Point the remote to the unit and press 2 on the remote. Them press system menu on the remote, you should be ok.
SOURCE: Alarm will not shut off after battery replacement
find a good auto electric shop and have them remove or by-pass this mess.It can be done,I recomend it.
SOURCE: I need to wire a 3 gang switches in a 3 gang box
before u start make sure power is off before working with electrical lines ---start with the 12/2 coming into box black [power] white [ground-neutral] and u will have 3 separate lines for the lights so u will have 4 lines total coming in the box== with the 3 light lines take the white and strip back the plastic and connect [wire nut] all 3 to the 12/2 white line --now take the 12/2 black line and connect it to the first switch gold color screw- bottom screw -now take some wire about 2-3 inch strip both ends and connect from the 12/2 black wire connection on the switch and connect to the gold /bottom of switch 2 than do the same for switch 3 connecting the wire from switch 2 so u will have power feeding all 3 switches-- now connect the black lines for the lights to the other side of each switch and ur done
I am not an expert but I have two of the remote controlled 8000 BTU units and one of the 12000 BTU units like this one.
I have found that the remote controlled Whirlpool units that used this type of electronics sometime had a problem with cold solder joints on the motor control board. This is the board that has the relays that control the fan speed and compressor. Check for cold solder joints on all connections that have large diameter wire. These connections apparently did not get hot enough to properly flow the solder on the large diameter wire.
